    Apr 2020
    35
    X Maxx questions
    Hey guys as you know I recently got an X maxx and itís so much fun! I do have some questions though
    1. How do I strengthen the body
    2. After a bad rollover I seemed to have bent the center driveshaft a little can I still use it like this
    3. Should I put the body over the side guards or behind the side gaurds
    Thanks for any help
    Mar 2016
    1,200
    Center drive shaft needs replacing
    Body in the side guards
    Body cracks repaired with e6000 / goop
    fabricator
    Apr 2015
    Tinley Park, IL
    241
    I just did my first run on my 4Pede new body.
    I reinforced it with fiberglass tape and Clear Flex Seal.
    It was an impulse buy. In hindsite I would have used another color.
    Looks tough though.
    I used Gorilla tape to reinforce my Maxís body. The cracks on the tailgate will need something more. Hmmmm, had some 3M ohvehicle wrap around here. Wonder how that would work.
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,136
    Drywall fiber tape and shoegoo or e6000 for the body. I found it easiest to put down the tape then glue over the top. Latex gloves to help keep glue off hands,. Otherwise peeling it off for a few days.
    After my body got toast even after the glue fix I went to a different body. Can pm me for info.. as can't talk about it in here.
    There is a body resistrctor mod that seems to help those that bash hard and keeping stock body. Prevents tailgate area from flexing down over rear shock towers. Best to do with a new body.
    And probably replace center driveline like other says unless you can gently bend it back well enough to work again. But probably best to get a replacement for when it fails again.
    Feb 2020
    670
    Quote Originally Posted by Smashem77 View Post
    Hey guys as you know I recently got an X maxx and it’s so much fun! I do have some questions though
    Thanks for any help
    Hi mate, in my case, I use duck tape to reinforce the body shell.
    The center driveshaft needs to be replaced, it's a very high precision thing and can't use if it's bent.
    The body shell will be put inside the side nerf guards.
