Results 1 to 19 of 19
    Aug 2017
    244
    Channel reversing.
    Looking for some help...
    I currently use the same remote for several rc's as it's much simpler.
    I have recently converted a TRX-4 Sport into a TRX-6. In this process, I added the hi/lo gear as well as the locking diffs.
    My problem is the hi/lo button is backwards and so is the diffs. I can have front locked or rear locked or all unlocked. But I don't have all locked.
    Is there a way to reverse the buttons on the transmitter or do I need to remove all servo's and horns and reverse them?
    Sent from my SM-G965W using Tapatalk
    Dec 2014
    Adirondacks
    1,416
    You should be able to reverse any of the 5 channels either by transmitter buttons or Traxxas link. It might be easier to ask "How would you like to set them up?"
    Aug 2017
    244
    The same way they are on TRX-4. The 3 position toggle switch should be as follows:
    Pos A = all unlocked
    Pos B = front locked
    Pos C = all locked
    Mine is :
    Pos A = front locked
    Pos B = all unlocked
    Pos C = intermediate locked, front and rear unlocked.
    The red switch should be press up for low and down for hi. Mine is reversed on my trx-6 but the same remote works fine on my TRX-4 with same functions
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    257
    Perhaps the servos are in the wrong channels? I know that on the RTR, the intermediate and rear axles are controlled together by one servo. Do you have a separate servo for each axle?
    Aug 2017
    244
    They are all plugged in the right places.
    Both rears on same servo but I am gonna try a shorter cable on the last axle. But ecen when I get the last axle settled, the switch will be wrong.
    Dec 2014
    Adirondacks
    1,416
    Quote Originally Posted by B-stinga View Post
    Pos C = all locked
    Mine is :
    Each receiver needs to be set up. If the receiver came out of a different vehicle other than a TRX-4 with all channels setup, they could be reversed like you are experiencing.
    If you have the servos plugged in the stock locations and you want the channels to work as it would come from the factory. (Using Traxxas servos)
    CH3-reversed
    CH4-reversed
    CH5-normal
    Do you have the Blue Tooth Link?
    Aug 2017
    244
    CH3-reversed
    CH4-reversed
    CH5-normal
    I was thinking along those lines...
    I can only find support to reverse the throttle and steering channels. But those are fine.
    I don't have the link module. I thought of it as a gimmick, but considering I run several trucks on the same remote, I see a potential usefulness. Will definitely look into getting that.
    Anyway to do it without it in the mean time?
    Aug 2017
    244
    Found it. I never realized there are this many programming options.
    Good to know!
    Tha ks for the help guys!
    Dec 2014
    Adirondacks
    1,416
    I don't use it much for the telemetry. It sure does come in handy for setting up the Tx/Rx settings.
    On the bright side, Ch3,Ch4,Ch5 you can only adjust servo direction. It should make it a little easier. LoL
    RC Champion NYbandit33's Avatar
    NY
    1,212
    The bluetooth module and link app is definitely worth it. I run both my cars off the same remote and planning on adding a third soon. Having the motor temp sensor and voltage tap has been very useful for me. Also very easy to change settings and create different profiles.
    Monster Baja Sla2h VXL
    Rustler VXL
    Aug 2017
    244
    Thanks again all. Job done, all channels set properly.
    I still can't get the rear axle to lock. I opened up the diff. Weird thing is it doesn't matter which position the locker is in, the wheel action remains unlocked
    Dec 2014
    Adirondacks
    1,416
    Is the shifting fork in the groove on the metal locker gear?
    Feb 2019
    California Bay Area
    257
    Yeah, the locking/unlocking diff is sometimes problematic. Take the diff cover off and see what happens when you push or pull on the cable.
    Aug 2017
    244
    It's where it's supposed to be. And the cable does it's job of moving fork from side to side.
    Aug 2017
    244
    I did that. I even manually pushed in the lock, but even in locked position the wheels are unlocked ( I can hold one still and the other turns)
    Dec 2014
    Adirondacks
    1,416
    Check to see that there is a pin.
    Aug 2017
    244
    That's why I love this place... right on the money grizzly, no pin. All set now, thanks!!
    Aug 2017
    244
    That rear locked axle makes all the difference
    Dec 2014
    Adirondacks
    1,416
    It's looking good!
