    Aug 2019
    62
    Can I use the traxx kit with my 6x6?
    Iíve got an awesome 6x6, however Iím not quite sure if putting the traxx kit on it would work or not. If I were to put front ones on, and the other 2 in the very back and take off the first set of tires, would that be the way to roll? Do any of u guys know?
    Feb 2020
    1,379
    Quote Originally Posted by XmaxxBasher1200 View Post
    I’ve got an awesome 6x6, however I’m not quite sure if putting the traxx kit on it would work or not. If I were to put front ones on, and the other 2 in the very back and take off the first set of tires, would that be the way to roll? Do any of u guys know?
    Of course, you can, the axles are the same as 4x4.
    Aug 2017
    251
    The picture is not mine**
    But I plan on doing it to mine this winter
    Sent from my SM-G965W using Tapatalk
    N. Idaho... Da Sticks!
    8,090
    Interesting...
    It looks like the TRX6 in the picture has been modified, the back axles have been separated a bit to make room for the tracks.
    So, in stock form, you cannot run the tracks on the TRX6. If you lengthen the chassis by about an inch and move the back axle (which also requires a longer drive shaft), you can use the tracks.
    Aug 2017
    251
    Interesting...
    I know he made it longer to have clearance, as it is 6 wheel steering.
    I will double check with my own which is standard length. I was thinking of putting my 4 Traxx on the rear axles and leave the tires on the steer (I am not willing to buy another set lol)
    Dec 2014
    Adirondacks
    2,270
    The Traxxas Tracks won't fit without modding. There is 130mm between the two axles. Not enough room.
    I measured the front tracks because they are shorter to show measurements. If you would put two tracks next to each other you would need at least 170mm. You would need to stretch the axle spacing 40mm. You would need some additional spacing for clearance between them.
    The rear tracks are about 100mm instead of the 82mm.
    Sorry about the picture quality.
    Dec 2014
    Adirondacks
    2,270
    I don't see why not. It would act like a stretched 4x4.
    RC Qualifier TITANIUM94010's Avatar
    Sep 2019
    San Francisco CA
    478
    Quote Originally Posted by B-stinga View Post
    Wouldn't that cause some kind of overdrive or underdrive? I'm not sure about the gearing of the Traxx but I would assume their geared less.
    Jumping: maneuver and pray it won't break.
    Aug 2017
    251
    https://www.facebook.com/groups/3007...5095376599059/
    Here is a video he posted on FB. When he posts one with the traxx I will share
