    May 2020
    61
    brake sleeve split on 4Tec nitro
    I ran a few runs with my 4Tec nitro and had a problem with the brake.* The plastic sleeve at the end of the brake linkage started to split.
    I can't seem to attach photos so here is a link to the image
    https://www.dropbox.com/s/y23k6jd7uz...-Link.jpg?dl=0
    How can I fix this problem?
    Thanks
    Tony
    135
    The piece that is split is a piece of fuel line. Just cut a new piece and attach. You may need to adjust the brakes to get them to work to your liking.
    Have a great day!
    Justin
    May 2020
    61
    Quote Originally Posted by Third Coast RC View Post
    Justin
    That is good news. I won't have to buy more expensive parts.
    Can you offer advice on adjusting the brake linkage?
    135
    I try to adjust the brake “caliper” so that it’s tight when brakes are applied but has sufficient play when not engaged (.5-1mm). Then I check for all tires for stopping when rolling by hand. I will error on less braking power over the tires locking up during high speed braking to save tire wear.
    Hope this helps,
    Justin
    May 2020
    61
    ... but has sufficient play when not engaged (.5-1mm).
    Justin
    Thanks for the help
    When you say brake not engaged would that be neutral?
    Just to get things going I did a quick adjustment. I adjusted the linkage so there is a little play at neutral but it does apply a little braking in neutral. Then the linkage applies full brake when the servo moves.
    Is that a good starting point?
    135
    Sounds pretty close. Try to ensure there is no brake engagement at neutral (drag). That will cause excess heat in the brakes and will effect stopping power.
    Have a great weekend!
    Justin
    May 2020
    61
    ... Try to ensure there is no brake engagement at neutral (drag). That will cause excess heat in the brakes and will effect stopping power.
    Justin
    I didn't notice that but will tinker with the adjustment as you mentioned
    Thanks
