    Jun 2020
    Proline trenchers for sc16 slash
    Iím told they should work for any 1.16 scale just wanna be sure and if I need any extra parts. Any input would be great, Iím new to the hobby. Hereís the description .Trencher 2.2" M2 (Medium) All Terrain Tires Mounted
    for 1:16 E-REVO & 1:16 SUMMIT Front or Rear, Mounted on Desperado Black Wheels
    SKU: 1194-11
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,553
    Wheels may rub the lexan body on the slash.
    Jun 2020
    Yea I think they will, my latrax tires on now are close so will have to cut. Or will getting a higher body mount work like from the summit if compatible? Any other parts u think? Small pinion maybe? It’s a 26 tooth on now. 26/50t on the titan12-T 550 any extra suggestions is helpful. Thanks
    Jul 2018
    beaverton oregon
    1,553
    May be able to just cut the body to make tires fit. Not sure on if longer posts are available.
    For gearing. It's putting on the tires and then running and checking on motor temps and performance and then gearing accordingly. If temps to high gear down some.
    Perhaps other will chime in with what they use.
    May 2020
    25
    Iíve been on the hunt for good replacement tires for the mini slash for a while now.
    I purchased these amazon tires as they were the only tires I found that were close in diameter to the original stock tire size
    https://www.amazon.com/Rowiz-Off-Roa.../dp/B01HCWDL68
    https://www.amazon.com/4-Pack-HobbyP.../dp/B071ZX9JB7
    The two options above are the exact same wheel but with different rubber. Hereís what they look like on my mini slash -
    As you can see in the pic, the wheel wells both front and back are cut back to accommodate the 76mm diameter. They will rub the body unless you trim it back. That said, the Proline Trenchers are 92mm in diameter so theyíre considerably bigger.
