Results 1 to 14 of 14
Thread: Help
    RC Qualifier Rico116's Avatar
    May 2020
    South Florida
    306
    Help
    Can anybody refer me to a video on how to put these shocks back on?
    Sent from my SM-G930P using Tapatalk
    Mar 2020
    24
    That's for the rear...
    https://youtu.be/1WHRaLWBBDw
    Gesendet von meinem VOG-L29 mit Tapatalk
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,573
    Put your rocker back on. But the shock in by the motor first. Then slide other end of shock into the rocker. It is slightly keyed some so will only slide in from one direction.
    May 2020
    South Florida
    306
    The rocker post came out all in one with the screw you know how you unscrew the one screw on the rocker arm and then the post holds it all came loose and the post came out along with the arm when unscrewing it it was really hard to unscrew becuase I was unscrewing the post too not even knowing but now the post is halfway screwed in and I dont know how to get it down there pushed all the way
    May 2020
    South Florida
    306
    More pics
    Jul 2018
    beaverton oregon
    1,573
    Two options.
    End wrench I think 8mm
    Or put the screw in the top. Then once the top screw is in keep going and it will turn the shock post.
    Hold onto post with end wrench or plyers to break top screw free and install rocker
    Jul 2018
    beaverton oregon
    1,573
    And as always with small machine screws, nuts, bolts, back turn (loosen) the screw till the threads engage and line up. Then tighten
    so you don't cross thread. Not cross threading on your Car will save ya hassle down the road.
    May 2020
    South Florida
    306
    THANK YOU!!!! Such a struggle trying to learn but that's how you learn
    RC Qualifier FoxhoundEP3's Avatar
    Jan 2010
    Lake Forest, California
    682
    Wait, did you fix the servos and then it broke again?
    Summit.Erevo 1.0.Slash 4x4.Stampede 4x4
    May 2020
    South Florida
    306
    Nah inspected the servos one of the gears was stripped to a pretty bad extent so I figured cut my losses bought a new Savox servo at the hobby shop In the process of putting it on doing my research I work on it tomorrow
    May 2020
    South Florida
    306
    Quote Originally Posted by FoxhoundEP3 View Post
    Jul 2018
    beaverton oregon
    1,573
    Quote Originally Posted by Rico116 View Post
    I think best way to learn is to fail. Then look why it failed and understand why. Kinda standard in engineering, understanding failure modes ect. If you understand how things work it helps with the overall view. Understanding why a part fails helps know what to do to prevent it.
    I googled up some vids today on gsg 22lr 1911 tear downs. found ones on the firing pin assembly, And some mods to do to a fix on the extraction and cycling issues I was having, took a while to implement. But fixing cheap manufacturing issues.
    May 2020
    South Florida
    306
    Yes good point made alot of it just comes from tearing Down and rebuilding cant be afraid to teardown
