Results 1 to 21 of 21
Thread: Mip help
    RC Qualifier kzsteve's Avatar
    Jan 2018
    norcal
    336
    Mip help
    i have an xo-1 with MIP hub adapters to run 1/5 tires . having trouble keepin the hubs locked to spindles .
    is anyone having the same problem ?? .......................... thanks .. steve
    XO-1 GUY GETTING OLDER BY THE MINUTE
    Eastern Shore, Maryland
    4,724
    Post some pictures of what happens, and maybe us guy who run stock can come up with an idea that will help.
    Jan 2018
    norcal
    336
    thank you , ill see if i can ............ steve
    RC Racer gusd2's Avatar
    Jan 2015
    136
    Are the hubs from MIP or EM Performance? I ask because I can’t find anything from MIP but lots of hits on a XO-1 adapter from EMP to accommodate 18mm square hubs.
    Nov 2018
    Livermore, CA
    886
    Quote Originally Posted by gusd2 View Post
    That’s what I though about too. I don’t know of any MIP converter to 1/5 wheels. If it’s from another manufacturer, machining tolerance differences can cause this. It may need more than locktite, for example maybe two locknuts sandwiching a locking washer or something?
    Jan 2018
    norcal
    336
    definately not MIP as i bought them WITH MY HEAD IN THE DARK ...................... thanks
    "*" are used by Traxxas's language filter to remove words that Traxxas has deemed as offensive or profane. IF they are placed there on purpose by you please do not do so as it can be seen that you are using profanity and infractions will be issued.
    Jan 2015
    136
    That’s cool. I didn’t see anything on their website. Drop a pic when you have a sec and we can help with your issue.
    Jan 2018
    norcal
    336
    my apologies , my head wasn't quite right ...... my adapters are EMP .......... thanks
    things are hot in ca. my hubs are EMP ... not mip ............ sorry
    Jan 2015
    136
    No worries man. I forget more than I remember these days.
    The other day, went to the hobby store to pickup a part for my Slash only to get home and find out I already had 2 of them! Lol
    Jan 2018
    norcal
    336
    when i go i forget why i went !
    so now that we know which hubs i have , any cure for my problem .
    i took 2 pix , but dont know how to post .............. steve
    Jan 2015
    136
    The iPad or iPhone app Tapatalk allows you to easily post pictures into these threads. If you’re accessing this forum via a web browser, then I believe you need a picture hosting site which can be a pain.
    Without seeing the pics, I’m not clear on what the issue is. Would you elaborate?
    Jan 2018
    norcal
    336
    talked to manufacture , so i think im ok .............. thank you ...... steve
    Jan 2015
    136
    Great!
    I’m considering the same mod to to run 1/5 wheels. What advice did the manufacturer provide to fix your issue?
    Jan 2018
    norcal
    336
    Great!
    they said to try locktite (blue) ......... havent had a change yet
    https://kzsteve.imgbb.com/. pix are here
    adapter comes loose from spindle ............. not much to see
    Jan 2015
    136
    I’m assuming you’re using the loctite on the screw pin that holds the adapter to the spindle. Is the pin backing itself out?
    Jan 2018
    norcal
    336
    not sure but think so . wheel & spindle comes off when power applied
    Jan 2015
    136
    Quote Originally Posted by kzsteve View Post
    I can’t wrap my head around how the screw pin can so quickly unscrew itself from the adapter. Is it fairly tight and snug when first installed?
    Jan 2018
    norcal
    336
    .. i tighten & retighten ... just made me look silly
    yes i do tighten . went to auto parts today ............. hmmm how much we miss in lock down ............ NEW to me ... Purple lock tite !! says softer than blue . so many to chose from ............. trying purple !
    Nov 2018
    Livermore, CA
    886
    The website for emp shows it comes with a washer and a lock washer for the spindle, I assume those go between the wheel and the hex hut? You see using those too right?
    Is the hex nut nyloc? If not maybe get same size nyloc nut so you have both that and the lock washer to keep the hex nut from backing out.
    Jan 2018
    norcal
    336
    mine are different . pix below . look at the hub ........... steve
    got it ready . see if it thows a shoe ...........
    Jan 2018
    norcal
    336
    wheel coming off
    got it ready . see if it throws a shoe ...........
    ok , got my head out & figured out why . i used Loctite (purple) on axle & set screws . (a lil dab will do you )
    also learned that there are set screws to hold pins in axle-hub pivots . yes my head was not in the sunlite !
    but all should be good now . thank you all for making me rethink my work ................ steve
