Results 1 to 11 of 11
    Apr 2020
    9
    Velineon VXL-3 3500 Brushless Motor & ESC Power System on TRX-4 bronco?
    Put on velineon VXL-3s Brushless on my TRX-4 bronco. Have one little problem with it. When l turn it on and give it full throttle it wants to go in reserve. Any one can help me out? Thank you.
    Feb 2020
    1,399
    Quote Originally Posted by Jamesbone View Post
    Hi mate, your problem is the motor rotation, change one of the wires (for example white to blue) of the motor to ESC an it works. The TRX4 motor is reverse rotation, and the brushless one is standard rotation. Do it I tell you and all works perfect.
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    811
    Yes, that is supposed to happen, since the extra portal gears reverse the rotation (that makes the tires spin the opposite direction). You can either change the settings in the transmitter or as Juanmacine said, switch the wires (only works for sensorless motors, switching the wires on a sensored may damage it).
    Apr 2020
    9
    Thank you. Yes it works perfect.
    Feb 2020
    1,399
    You're welcome.
    Jun 2020
    Hi Jamesbone,
    Does the VXL-3 3500 give the Bronco more top speed?
    Apr 2020
    19
    Yes, it should, as it should spin higher RPMs than the 21T stock motor. You likely wouldn't have really good low speed control, though
    Feb 2020
    1,399
    Quote Originally Posted by 314bldr View Post
    With a brushless sensorless system, at high KV and RPM, the low speed control gone, unless the motor has more poles, 4 or 6 minimum.
    Apr 2020
    9
    Yes, have a 48 tooth spear gear with a 13 tooth pinion gear. It's crazy fast. Low speed sucks. But l wanting more for a speed run truck. Enjoy drive it. Stock tires balloon to much. Looking into buying better tires for it right now..
    Oct 2018
    276
    Some 2.8 proline mashers look good on a bomber (rock bouncer). Might want to look into those. Pretty wide, might have clearance issues with turning though.
    Jun 2020
    Thanks for the insight.
