Results 1 to 14 of 14
    Jan 2019
    [Typewriter noises] . . . Somewhere in the Eastwest . . .
    264
    Brushed Mod Motor Questions
    I recently picked up an open-endbell motor and have a few questions. Since that is a piece of equipment that was common for vintage electric vehicles, I figured this was the correct forum.
    1. I've heard that taking an eraser to the commutator and brushes is a good way to clean them after using motor spray, but I can't get any erasers down to the comm. What do you recommend?
    2. I took the springs off my brushes and took them out, and got a few photos. This was before cleaning. Does this look normal?
    3. Is the black coloration bad or does it mean anything at all?
    4. I would just like to check that the motor is properly timed. Is this correct for 0 degrees?
    5. Do you have any recommendations or advice for a first time owner of an open endbell motor? Are there any other photos you want me to take?
    LONG LIVE THE PROFESSOR! Rest in peace, Mr. Peart.
    Traxxas Employee nixhex32's Avatar
    Mar 2001
    Ft Worth, tx
    517
    You can actually pull it apart and Clean the comm with it out of the can. Just remember the orientation of everything. Or look online for a comm cleaner tool. They used to make them, about 2-3" long with one end that fit down the brush hood.
    TRX4(lots of mods), TCP(will stay with me), Custom Summit, GTP Fiero(in rebuild stage), "My Summit" pic is posted in the Summit gallery........and some other things.
    Mar 2001
    Ft Worth, tx
    517
    You could also look for a comm lathe but for just one motor it probably isn't worth the money to you...... unless you find a super cheap one.
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    38,065
    Those brushes look like they have a lot of life left in them yet. Some discoloration will be normal due to wear and heat. As for the timing, it's hard to tell from that picture. Part of me wants to say that that's 0 degrees of timing, but another part wonders if it's actually negatively timed. I'd need to see a clearer image to know for sure.
    I enjoy working on old brushed motors. I even went so far as to get a lathe for truing the comms many, many years ago!
    Jan 2019
    264
    Thank you both for your help! I'm glad that it looks normal, because I have no experience with these.
    nixhex32, you mentioned taking the armature out. How do I do that?
    With all my research on the internet, I couldn't really figure out what negative timing does. Do you have an answer?
    I was not concerned about brush life, because I had about 7 runs and break-in on the motor when I took those pictures. I do not think that I will be getting a comm lathe, because the cheapest one I have found anywhere was 300 dollars. I'll work on photos for you all of the endbell from a few different angles. Thank you again!
    Mar 2001
    Ft Worth, tx
    517
    There should be 2 screws that hold the end bell on. Just remove those and the internal ring, then the armature pulls out. Keep an eye open for any spacers or washers though.
    I wouldn't play with the timing to much, not without a dyno for it. MAKE SURE to note the timing if you take the motor apart.
    Yes the comm lathes are not cheap, I still have one from the 90's when I used to race. Now its just a reminder of the old days.
    Quote Originally Posted by Is_It_Broken? View Post
    Traxxas Marshal
    Mar 2003
    38,065
    $300 is definitely a bit much. I bought one from Trinity around the time BL motors were gaining traction new for maybe half that.
    Negative timing is almost always going to be a bad thing, resulting in less performance, more heat, and more wear. Negative timing is only really useful in situations where you'd be running the motor in reverse rotation. I typically run between 6-12 degrees of advanced timing on motors with adjustable timing for what it's worth.
    Jan 2019
    264
    Thank you again! Sorry it took so long to get these photographs, somehow life managed to happen right now.
    I have two photos of the negative brush spring. I am guessing that the one where it against the endbell is the proper position?
    ...and here are some photos of the endbell with better lighting:
    Have a nice day!
    Traxxas Marshal
    Mar 2003
    38,065
    Yeah, the brush springs need to be fully seated. One of those definitely needs to be pushed down.
    As for timing, I'm pretty sure you want to advance it a little for it to be at 0. The pointy bit is likely pointing at the motor's timing.
    I always thought those endbell heatsinks looked cool, ever owned any.
    Jan 2019
    264
    I have now re-timed my motor, and cleaned the commutator while it was at it. I would have looked at the armature, but my 1.5 mm hex wrench has walked off, so I couldn't get the pinion off. I hope it is not in the A/C system. This was really easy, with the most stressful part being that the endbell screws apparently use Freedom Units TM
    I don't have a 4 slit arm, it just took 4 photos to include all of the comm.
    Traxxas Marshal
    Mar 2003
    38,065
    I doubt that motor has seen much use, the comm. appears to be nice and uniform. As the comm. wears, it'll change shape (which is why you'd use a lathe to true it up again).
    Jan 2019
    264
    First of all, a huge thank you to cooleocool and nixhex32 for helping me with this adventure!
    In a longer term update, after I regeared it to take advantage of the better operating temperature, my motor sounds healthier, runs cooler with more timing advance, is faster, punchier, and extremely efficient. I actually cannot fully charge my battery because the car simply will not drain it down to storage voltage in the amount of time I have to play! The motor still heats up quickly in the grass, but once the grass starts dying that won't be an issue. I was able to drive for over an hour this weekend and the car never got over 140 F.
    Once again, thank you both!
    Traxxas Marshal
    Mar 2003
    38,065
    Very nice, glad to hear things are working out well for you!
    Oct 2020
    Orlando
    4
    That's great that everything works.
