    Jun 2020
    Replace steering servo?
    Hi, I am a proud new owner of the 1/10 Summit. I've had it for a few months and recently I am into some upgrade work. I firstly put PL Trencher X tires on it for the good looking, but immediately one of the steer servo got stripped. I was wondering if I just got bad luck and if gears are replaced it would be fine, or it's due to the new tires are heavier than the stock ones so that I need to upgrade the servo to metal gear or even replace both to stronger ones. Advices are much appreciated. Thanks!
    Dec 2003
    Dekalb, IL
    3,267
    Stock servos aren't that great. I'd upgrade to something stronger/metal geared.
    If money is a concern, you can try a servo I started running recently in my ERBEv2 and Outcast 6S with trencher 3.8 standard tires. I run it at 7.2V though, so I get a bit more torque/speed out of it than a 6V system would. Still, it's relatively cheap and if it isn't enough for you, get a second.
    Looks like they are on sale again for $36:
    https://www.rcjuice.com/hobbystar-hc...ler-servo.html
    I run a single on both trucks with the trencher 3.8's and so far, it's doing well.
    Jun 2020
    Thanks for the reply! I know a stronger servo need more voltage to work but I am wondering how do those third parties compare to Traxxas servos in terms of compatible to stock ESC. Also if I want to do a single servo, do I just connect one servo and let the other side free? Does anywhere else need more upgrade, for example the servo horn?
    Dec 2003
    Dekalb, IL
    3,267
    I don't know what servos work with the fully connected traxxas receiver. I never used it, I use spektrum receivers.
    I run the stock servo horn with my single servo, but I cut off the other side of the arm so it doesn't snag on anything. I also replace the stock servo saver spring with the HD one and I typically use whatever HD horn comes with the servo I buy, usually have to cut it/grind it down to fit with the servo guard in place.
