Results 1 to 15 of 15
    Sep 2019
    204
    Aluminum C hub s help
    Does anybody recomend a c hub that is not very fragiles? I would like to hav less steering blocks play and have less wearing and friction and to adding some durability
    Sep 2019
    204
    (A aluminum c hub)
    Sep 2019
    204
    Does anybody know a durable aluminum c hub to recommend for a heavy traxxas slash?
    I have to do this to correct words
    Jun 2014
    San Gabriel, California
    8,466
    I’ve used the aluminum ones by Traxxas and by Hot Racing. No complaints for either one.
    Have fun!
    Indianapolis
    14,572
    The ones that come stock on the Ultimate and Platinum edition Slash 4x4 trucks are amazing! I have been running them on trucks since 2011!
    RC Racer gusd2's Avatar
    Jan 2015
    136
    Same here, have used the Traxxas aluminum c hubs on all my vehicles. Never once bent or damaged any.
    Dec 2003
    Dekalb, IL
    3,360
    I tried traxxas and aftermarket alloy ones (hot racing, atomik) on my stampede and they get slop in them pretty quick (read a summers worth of bashing) and I found some that use bearings for the king pins. I've only bashed a couple times with them, but I was unreasonbly hard on it... busted an MIP axle, torched an RPM arm, broke the ackerman bar... the c-hubs are still perfect.
    GPM SLA019A is the part:
    I was concerned about the kingpin bolts they use, but they seem to be holding up fine:
    Pretty sure there's another company that makes them with bearings, but I'm not remembering it now.
    Sep 2019
    204
    This is what i wanted thnk you alot
    This is absolutely perfect
    So i would not need to worry about fully tightening the
    The shoulder screw because of bearing
    Does the c hub support a kingpin with c clips?
    And also everyone thnk you for your helping
    Jun 2014
    8,466
    How heavy is your Slash 4x4? What have you done to it?
    I would like to see your creation... post some pics please!
    Sep 2019
    204
    Many things
    Sep 2019
    204
    Ha ive planned 1/8 motor and a heavy battery and my driveline has fully steel and also a weighr in the front and heavy loads spring
    Sep 2019
    204
    I dont know how to place a picture
    Dec 2003
    Dekalb, IL
    3,360
    Quote Originally Posted by LargeCar1999 View Post
    It may have come with hinge pins... I can't recall, I used 3x50mm bolts with locknuts and cut them down so they are fully captured and I hate using c-clips if I don't have to. The kingpins use the specific shoulder bolts I pictured that came with the c-hubs.
    The 3x50mm bolts I used have the unthreaded portion just long enough to stick out of the arm to require a 1mm or so shim to remove slop with the locknut tight.
    Mines not light, but it's a stampede 4x4 with a slash chassis. They use pretty much all the same parts, which is why I mentioned the c-hubs I'm using.
    I run a 1/8th system in it currently on 3S and I drive it like I stole it most of the time.
    MIP x-duty's on all 4 corners
    t-bone center shaft (had to get the longer one when I changed to a slash)
    2.8 trenchers with 17mm wheels.
    Sep 2019
    204
    Pounds 11
    Also my traxcas slash may weight more
    Dec 2003
    Dekalb, IL
    3,360
    Integy offers some with bearings as well. I knew I ran across another set besides the GPM ones:
    https://www.integy.com/st_prod.html?p_prodid=8463
    Not sure how good they are, but appears they use the stock king pin/shoulder bolts.
