    406
    Cant turn steering/wheels when truck is off
    Is it normal if I cant steer/turn the wheels manually when the truck is off? My servo/steering works great when the truck is on but i was going to clean the inner wheel hubs but i cant turn the wheels without power to the servo. Is this normal?
    Also, should i upgrade to the 2085x servo or are there any better alternatives if i wanted metal geared servos?
    Thanks!
    Oct 2016
    4,809
    Tighten your servo saver, and yes there are options, for a drop in replacement there’s no better option thank the 2085X. Traxxas makes a mount that allows you to install and standard servo, if you choose that route.
    Mar 2016
    1,340
    Steering locked when off - normal
    2085X upgrade servo
    or 2087X metal gear set for the stock 2085 servo
    fabricator
    Feb 2020
    1,360
    Quote Originally Posted by CrazyXMAXX View Post
    2085X upgrade servo
    Agree with this, the servo blocks when is off.
