Thread: Diff gear?
    Aug 2017
    217
    Diff gear?
    Does anyone like Hot Racing Steel Helical Spiral Differential Gear Set? If so why or why not. Thanks.
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,491
    Quote Originally Posted by Forrest View Post
    For bashing I just stick to stock. Cheaper to replace once broken.
    Sep 2015
    45
    If you're blowing out rear diffs try getting a center diff. The science behind the helical gears means the diff is more quiet and efficient than straight teeth but a center diff will fix diff gear stripping issues.
    Sent from my SM-G973U using Tapatalk
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,412
    If you are talking about - https://hot-racing.com/?partnumber=VXS9282X02;c=455
    These are awesome hop up parts but expensive and near impossible to find since they haven't been being made for over a year I believe. They are great if you have the newer diff housing with the cross screw. If you have the older design the new thrust angle created by the helical cut to the gears will cause problems still.
    May 2017
    6
    Available right now! Havenít had a diff problem since I got these! Minimizes flexing and movement of the housing!
    Sep 2015
    S.E. Michigan
    1,412
    Quote Originally Posted by Partsmaster2010 View Post
    Sweet! Nice to see them back on the market.
