    May 2020
    S e SD.
    46
    Help wiring tqi reciever
    Thought I took a picture of this after I took the cover off , but no stuff .looked on my stampede but it doesn't have the wires coming out above rear driveshaft . That is the on in the picture. The connector is blue . Can someone please give me a response as to where it is supposed to connect . Thanks in advance .
    Sent from my moto z3 using Tapatalk
    Dec 2014
    Adirondacks
    2,266
    It's part of the telemetry. It's the rpm sensor. Plugs into the rpm slot.
    May 2020
    S e SD.
    46
    Excellent , thanks alot .
    One more ,,,,
    I hooking up a hobby wing max 10 sct esc . Their instructions say that there is a throttle cable that hooks to th channel on the receiver . No markings like that on tqi . It has a port that is marked vt rest of ports are marked as different battery channel numbers . It's the connector off of the esc that I'm trying to hook up to the receiver .
    Dec 2014
    Adirondacks
    2,266
    CH2 on the receiver is where an ESC plugs into for throttle. CH1 is the steering servos. Remember that the Traxxas receivers have 2 CH1 slots. So the ESC should plug into the 3rd slot up from bottom.
    May 2020
    S e SD.
    46
    Ok then , esc goes into port 3 . Thanks huge , you really did me a solid and you did it in real time . Love this place . Thanks again
    Grizzly 03 .
    Jun 2020
    Texas
    215
    It has the ports listed in the manual FYI
    May 2020
    S e SD.
    46
    Yep , the manual is good , but you guys are better . I will refer to it before posting anymore basic questions .
