    May 2018
    96
    Street Slash shock question
    Hey all,
    I'm looking to make my slash 4x4 into a lowered street truck.
    I am looking for info on the size shocks that would work good to get it as low as i can.
    I do have the LCG conversion kit, going to run the Mickey Thompson 2.2/30 beadlocks with street tires.
    Thanks in advance for any help with this.
    14,224
    GTR shocks, nitro fuel tubing around the shaft inside the shock body, variable damping pistons with the valve on the bottom and XO-1 or Revo springs.
    RC Racer gusd2's Avatar
    Jan 2015
    136
    +1
    You nailed it perfectly.
    Nov 2018
    Livermore, CA
    793
    Mount the stock shocks with the top in the inner most hole and bottom in the out most hole gets the car pretty dang low, try that first and play with fluid weight and preload spacers first, if that doesn’t quite do it then others already gave great pointers. The stock shocks are pretty good for street bashing.
    May 2018
    96
    I ordered some Nitro tube, and the XO-1 springs. Figured i'd start there using the stock shocks. See how it goes.
    Thanks for the responses so far.
