    Jul 2020
    9
    Question How to check if battery is compatible?
    Hello,
    I see in my country a lot of Lipo Battery brands since Traxxas is very expensive here. How can I check if it will fit a car or not?
    For exemple, considering a Rustler 2wd VXL. Is this battery bellow compatible with it?
    http://www.maxgphobbies.com.br/bater...-3s-11-1v.html
    Does these batteries have different sizes or there's a standard for all?
    thanks!
    Jul 2020
    UK
    5
    looking at the batteries that can fit in the rustler 2wd VXL if the dimensions of the battery you linked is smaller than those ones, then it should fit. Make sure you have any connector adapters you might need
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    670
    From looking at the specs of the battery, it should work with the ESC and motor, but I am not sure if it will fit into the battery compartment (you may need the battery tray expansion kit). To see if a battery is compatible, take a look at the ESC and motor specs and compare them to the battery specs. They are compatible for most of the times.
    There is no "standard" sized battery that works with everything, so be aware of the specifications of both the ESC and battery.
    Feb 2020
    1,217
    Quote Originally Posted by bleise.cruz View Post
    Hello,
    thanks!
    These batteries works perfectly with your rig.
