Thread: New Tires
    May 2018
    23
    Question New Tires
    I have a 4-tec 2.0 that has a 35T-55 ratio (70 mph/112 kph) and I am going through tires pretty fast, and I am looking for a better wheel/tire to use. I am looking for anything that last long but still has good strait line grip. Also should I go foam or stay rubber?
    I am not a racer and mainly drive on asphalt and concrete.
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    674
    Foam tires offer better grip, and also wear out less. However, foam tires chunk out easily (chunks of foam may get chipped if it goes on terrain that is too rough for it). The stock tires are the longest lasting tires that I am currently aware of (other tires are more race/grip oriented).
    Sep 2017
    119
    That gearing on 3s is epic, i tried it for a while on contact foams, the foams last well but you need to remember they are foam not rubber, if you slide around and drift you will chunk the edges out, if you just run circuits on and off throttle they will last you a long time.
    I now run 29/62 and it's still awesome but more controllable.
    Fwiw i run 26mm up front and 30mm rear, around 35 to 40 shore and as their cheap i buy 3 or 4 full sets at a time.
    Sent from my POT-LX1 using Tapatalk
    Jun 2020
    9
    I second contact foam tires, last me 3x as long as rubber. No issues with chunks, running 3s. 55/35. I tried more expensive foams tires and wore out faster.
    Jun 2003
    44
    Quote Originally Posted by MikeyRC View Post
    Please review how you mount the contact foams. I read review on Amain that said the 30mm set did not fit a 4 tec 2.0. Thanks for any info.
    X-Maxx_Maxx_Rust4x4vxl_TRX-4_Slash4x4_Rally_4Tec2
    Sep 2017
    119
    I totally forgot to mention, i run 10mm extenders on each corner, like these. No slop, great fit.
    It dosent extend the car by 20mm as the wheels have a negative offset.
    Aug 2020
    Kansas City
    130
    Do you have a link to amazon or ebay or someplace for these? I would like to run non-hex tires as well as hexed.
