Results 1 to 11 of 11
    Jul 2020
    6
    Wide Kit and metal drive shafts = steering problem.
    Hi,
    I installed the wide kit and steel drive shafts.
    When I turn the front wheels the drive shafts rub on themselves inside the hub. They rub so much the wheels slow down.
    The metal shaft rubs on the part that goes through the bearing.
    Any ideas what I have done wrong?
    Charlie
    Sep 2015
    2,337
    Take a picture or video.
    youtube.com/c/RazorRCvideos
    Jul 2020
    6
    Quote Originally Posted by RazorRC22 View Post
    Here is a video
    Dec 2014
    Adirondacks
    2,116
    Does it do it if you turn it the other way?
    You might need to adjust the servo endpoints.
    Jul 2020
    6
    Hi,
    Yep it does it both ways
    I am getting the Bluetooth for the remote so will try and adjust the end points.
    Sep 2015
    2,337
    Yeah, just adjust end points and you should be good. That's plenty of travel.
    Jul 2020
    6
    Thanks guys!
    I will adjust and see if that helps.
    Should I also put grease inside the joints?
    Mar 2016
    1,321
    Dry lube on the cvd’s
    fabricator
    Mar 2016
    1,321
    Sure
    Looks good
    fabricator
    Dec 2003
    Dekalb, IL
    3,267
    I've had good luck with wax based lube on my cvd's over the years. I use white lightning clean ride.
