    Mar 2020
    Portland, Oregon
    80
    What is a good Rustler 4x4 vxl cooling fan for motor?
    What is a good Rustler 4x4 vxl cooling fan for motor? I recently got one and want to keep the temps down. I do not have the heat sink. anything that is easily mounted onto the motor? please Help! thanks!
    Nov 2019
    100
    I like this style
    Best blend of mass, surface area and airflow with the space available IMO.
    Nov 2018
    Livermore, CA
    730
    Iím partial to the dynamite 1/10 motor fan. Itís not flashy being a plastic case around the 36mm can, but its plastic construction is durable, and comes wired to go on any open channel on the receiver so it doesnít take up the esc fan connector.
    If I recall correctly the stock esc tend to heat up before the motor so having the esc fan connector reserved for the esc fan allows maximum cooling of the esc.
    Aug 2020
    Garden Grove, CA
    20
    Nitro Hobbies on Ebay has a nice one, I currently run it on my Rustler. Search for Nitro Hobbies on Ebay.
    RC Qualifier MECHANIC77's Avatar
    Sep 2016
    Canada
    445
    I'm not a great fan of plastic fan unit because it does not absorb and transfer any heat from the motor, in my opinion it better have an aluminum unit which will act like a heat sink and will work in conjunction with the fan to provide a better heat dissipation.
    This unit absorb motor heat a allows the fan to flow the air directly on the motor.
    https://www.ebay.com/itm/RC-EP-Elect...72.m2749.l2649
    This fan provide a RPM speed of about 28K and is made from aluminum which act like a heat sink.
    https://www.ebay.com/itm/SURPASS-Alu...72.m2749.l2649
    Good driver. Bad setup. Bad things will happen...
    Mar 2020
    Portland, Oregon
    80
    Quote Originally Posted by cgrant26 View Post
    I like this style
    I got this one but it the fan broke just after the first few jumps.
    Sep 2016
    Canada
    445
    Quote Originally Posted by NitroRusty123 View Post
    The problem is that the seven blades fan unit has thinner and less wider blades than the five blades fan and it tends to break easily during impact. Also with a five blades unit it will be more resistant in case that a pebble enters into the fan.
