Results 1 to 2 of 2
    Jul 2020
    13
    Question 2wd Gearing Suggestions
    I have a
    Motor
    Watts: 820W
    Max voltage: <12V
    Max Amps: 66A
    KV(RPM/Volt): 4370KV
    Max RPM: 50000
    Diameter: 35.8mm
    Length: 50mm
    Shaft length: 15mm
    Shaft diameter: 3.175mm
    Plug type: 4mm golden banana plug
    -ESC
    Item name: waterproof ESC
    Continue current: 60A
    Burst current: 320A
    Battery: 2-3S Li-Po / 4-9S Ni-Mh Ni-Cd
    BEC output: 5.8V / 3A
    I was thinking of going from p48 T19 spur with a p48 T90 slip to A p48 T28 spur and p48 T83 slip. I have way to much torque to the point if I dare touch my cervo during take off it spins around and around. This should lvl me out give me less torque and more top end?.?.(Right???). (I hope)
    Thoughts?
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,395
    On my 2wd rustler I run 14p 90spur. Will still do wheelies at 30mph Can make slipper a bit loose or adjust throttle sensitivity or punch depending on what esc you have.
