    May 2020
    3
    Pinion gear stuck
    Iím trying to change out my stock pinion gear, set screw came out easily but for the life of me I canít get the pinion off the motor shaft. I donít want to pry it off and I donít have a gear puller that small. Iíve tried pliers and a little WD40, itís moved but not off. Any suggestions would be appreciated.
    Aug 2015
    737
    Try heating it with a cigarette lighter or some other smalll heat source, there might be loctite between the gear and shaft.
    May 2020
    3
    Thank you. It finally came off with some elbow grease!
    Aug 2015
    737
    No problem, glad to help.
