    Jul 2020
    11
    Maxx - Steering Drift after crash
    So I was doing a 4S speed run on my street...at about 40mph and lost it...barrel roll down street. Only thing that happened was the right front wheel steel driveshaft popped out of cup. Took front end apart and check everthing. All looked good. Reassembled and now I am having to continuously tweak my steering trim back and forth to keep the truck going straight. Any suggestions??
    Dec 2014
    Adirondacks
    2,116
    Did you adjust steering trim with TSM off? It needs to be off when doing steering adjustments.
    Mar 2016
    1,321
    Usually a sign of a failing stock steering Servo saver
    fabricator
    Jul 2020
    11
    Thanks. Yes I did adjust trim with TSM off (which why they put TSM on these trucks is beyond me....just another sales gimmick). I think the servo saver is a bit worn. The ESC is a loose, but the receiver is still very tight.
    Jul 2020
    11
    One more comment...at slow to moderate speed truck holds straight line. The pulling starts at higher speeds. Any thoughts? I checked bellcranks and servo and they all appear tight.
