Page 2 of 2 FirstFirst 12
Results 41 to 78 of 78
  1. #41
    Jul 2020
    115
    Quote Originally Posted by patmanz28 View Post
    I would say stick to basics. remove weight on top for crawling. What size battery are you using? have you modified the stock tires? have you altered the shock preload? cutting the tires, and trimming the battery tray (using a 2200 3s) made the biggest improvement for my vehicle.
    I'd rather maintain the weight on top as part of the hobby for me is enjoy the look of what I climb with, else I would just use the chassis
    I'amusing a 3S 5000mAh battery, I haven't changed the tires or the shock preload. What needs to be done there?
  2. #42
    Jul 2020
    115
    Rock Climbing Advise
    If you want to learn about soldering, watch Holmes Hobbies vids. I've learned so much from them.
    That blue in that last pic looks majestic
    Sent from my moto e5 cruise using Tapatalk
    Thanks Mate, see the photo from yesterday
  3. #43
    Jul 2020
    115
    Hello, some videos to enjoy
    https://youtu.be/mUntc0eLzxA
  4. #44
    Jul 2019
    Washington
    90
    Upgrading the motor, esc, and steering servo will improve your crawling capabilities but it will not make you better.
    Learn your truck, the terrain you drive on, and the style you drive. Once you have that knowledge, then start upgrading.
  5. #45
    Jul 2020
    115
    Quote Originally Posted by dllnwtsn View Post
    Thanks mate, practice practice practice.
    I currently find mud pile to be difficult as I just sink in.
    The rocks are not as hard as we get enough traction.
  6. #46
    Jul 2019
    Washington
    90
    Quote Originally Posted by deuter View Post
    You need more power, that's where that AXE system comes in. A better steering servo will also help with the mud.
    It'll take a few trials before you find those "weak" spots.
  7. #47
    Jul 2020
    115
    Itís way harder than rocks, I just sink in
  8. #48
    Jul 2020
    115
    Some more rocky terrain today
    https://youtu.be/VVyCGz-I-II
  9. #49
    Dec 2014
    Adirondacks
    2,114
    Looks like your having a fun time. Rocks and mud are definitely different setups. Rocks you go slow with control and mud is about flotation with wheel speed.
  10. #50
    Jul 2020
    115
    Thanks Mate, itís a lot of fun.
    Somewhat an escape from reality.
    So what youíre saying is I have to drive in high gear over mud?
  11. #51
    Jul 2020
    115
    Some action today.
  12. #52
    Jul 2020
    115
    Wanted some tips on how I can climb these, just get wheel spin.
    Then I eventually managed to jump up to here.
    Another classic example of elevation I cannot climb.
  13. #53
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    666
    If your car gets stuck, try turning the front wheels, while applying throttle, slowly at first, and if that doesn't work, give it some more wheelspeed and turn the front wheel. One thing that I do is to take off the body and rock crawl hard parts without the body. Then I try again (same path, same place) with the body on. Also, I think the terrain is a bit unrealistic for a top and rear heavy truck, maybe go with something less jagged or steep? If you want to performance crawl, it would be much easier if you had a lighter body. Just my opinion, though.
    Good luck!
  14. #54
    Oct 2016
    4,774
    Good luck!
    I agree with this. Youíll need better tires and foams to stand a chance. But I think a winch may be your only option with your current equipment.
  15. #55
    Jul 2020
    115
    Any recommendations for Crawling tires and foam for TRX-4
  16. #56
    Aug 2020
    Ive found that the Canyon Trails are pretty good tires for stock.
    took a dremel to my stock canyon trails and grooved them.
    I also started to remove the little nubs on the center lugs. Tedious job so I only did the outers and Iíll finish it this winter.
    They do very well on my slick granite rock walls at home. This is compared to Hyraxes and Landmines in the same walls.
    Iíd have no problems running them if thatís all I could have.
    Might be an option to consider since it doesnít cost anything except time.
    ETA - I would get rid of the spare tire in the rear. It looks like thatís hanging you up in the picture.
    Those would be my attempts at easy improvements.
  17. #57
    Oct 2016
    4,774
    Others can chime in, but I run Hyrax and dual stage foams on aluminum bead locks
  18. #58
    Jul 2020
    115
    Some rocks today
  19. #59
    Apr 2020
    The Loir Valley, France
    82
    Quote Originally Posted by Benp View Post
    I also started to remove the little nubs on the center lugs. Tedious job so I only did the outers and I’ll finish it this winter.
    I’d have no problems running them if that’s all I could have.
    Might be an option to consider since it doesn’t cost anything except time.
    ETA - I would get rid of the spare tire in the rear. It looks like that’s hanging you up in the picture.
    Did you do a "before and after" test with the cut tyres? I've seen a few videos about cutting/grooving the stock tyres, but there was little proof of a performance improvement. Be interesting to know.....
    Stephen
    An Englishman in France
    Vallee du Loir.
  20. #60
    Aug 2020
    Quote Originally Posted by sarthetrx4 View Post
    It was an improvement. Tires still spun on the rocks but not as bad as when bone stock.
    I still have them on stock rims and foams.
    Iíll break them out every so often and Iím still able to run where my hyraxes and Landmines go. Maybe a little more effort with the CTs.
    So Iím definitely not being held back using them.
    Very underrated imo.
  21. #61
    Oct 2011
    81
    IMO cutting the stock tires is a massive improvement on the rocks. It was one of the best mods i think i have done. I just sat down with some snips and cut all 4 next day i went out and was hitting lines that seemed impossible just a few days prior.
    also that 5000 3s battery is wayyyyy overkill. a small 2200 3s changes that thing on the rocks like you would not believe. I use on that big when out on the trails and its fun to drive forever, but on the hard rocks it just flops on its back all day.
  22. #62
    Apr 2020
    82
    Interesting. It maybe a job for one of those long winter days!
    Stephen
    Vallee du Loir.
  23. #63
    Jan 2015
    Salado Tx
    222
    Ditto on the stock tire snipping. I also star cut the stock foams and that combo was a major improvement. The foam cutting decreases the side hilling somewhat due to the sidewalls will roll a little but the tire grip on any type of course rock surface is way better. FYI, put the tires on a piece of foil wrap and in the oven at 350 for about 10 minutes and the glued tires came off very easy so I could cut the foams.
  24. #64
    Jul 2020
    115
    Iam definitely keep to improve the performance with climbing, yesterday there was line which I walked all the way it was just not driveable.
    Rather than snipping my wheels I would prefer buying something that is made for strenuous climbing.
    I believe we need something that sticks to the rocks like glue?
  25. #65
    Feb 2019
    California Bay Area
    666
    Proline hyrax tires work pretty well. It might rub on the body when turning, since it has edges that stick out more than stock.
  26. #66
    Jul 2020
    115
    Cool, will check them out.
  27. #67
    Jul 2020
    115
    What seems to be the problem here, the performance is gone downhill, cannot crawl at all.
    https://youtu.be/yuFm6c9szlE
  28. #68
    Jul 2020
    115
    I did manage to get some driving in:
    https://youtu.be/xX7OCF3hddw
    https://youtu.be/VuGdbvXv6MM
    https://youtu.be/-QUqOApkZ4k
    https://youtu.be/-UwNrQiQN_8
  29. #69
    Jul 2020
    115
    I posted a climb a while back , which seemed impossible to do and I thought letís try it with the chassis only.
    Someone on this thread said they do that to understand what the trx4 is actually capable of if had the right weight body.
    https://youtu.be/P5x9MOoZJKc
  30. #70
    Dec 2014
    Adirondacks
    2,114
    Slipper clutch could be loose and slipping.
  31. #71
    Jul 2020
    115
    Thatís what everyone said, I did end up checking it and the nut was fairy tight.
    It was my right rear tyre that was running flat, swapped it with the spare and the vehicle was as good as new.
  32. #72
    RC Qualifier TITANIUM94010's Avatar
    Sep 2019
    San Francisco CA
    458
    I posted a climb a while back , which seemed impossible to do and I thought let’s try it with the chassis only.
    The TRX4 is an extremely capable crawler, just the body will drag that performance to (literally) rock bottm
    Jumping: maneuver and pray it won't break.
  33. #73
    Jun 2014
    San Gabriel, California
    8,386
  34. #74
    Jun 2014
    8,386
  35. #75
    Jul 2020
    115
    This the top tire to get for the defender if crawling.
    https://www.metrohobbies.com.au/prod...es-2pc-for-f-r
  36. #76
    Jun 2014
    8,386
    Yes, but the vids posted above are free mods... just costs some of your time.
  37. #77
    Sep 2019
    San Francisco CA
    458
    Yes, Hyraxs are some of the best tires out there, they're amazing for rocks, but they can be a little slippery in wet terrains, and especially on mud.
  38. #78
    Jul 2020
    115
    Quote Originally Posted by TITANIUM94010 View Post
    Thanks ordered a few
