    969
    Rear upper front facing a-arm screw removal
    Sorry if this has been asked, but the search feature makes it hard to search for a-arm
    whats the trick to getting at the Rear upper front facing a-arm screw?
    May 2018
    18
    Remove rear facing screw. Remove hinge pin. Remove upper arm and then you can get to and remove the screw you are speaking of. Just remember to put it back in the arm first before you reassemble.
    Feb 2020
    1,363
    Quote Originally Posted by strick9440 View Post
    Agree with this.
    969
    i see, there is no need to unscrew it while on the car itself. thanks for the tip
