Page 2 of 2 FirstFirst 12
Results 41 to 61 of 61
  1. #41
    RC Champion mrtwohands's Avatar
    Aug 2012
    Warner Robins, Georgia
    1,940
    That's not bad for hitting a tree. If that's the first time I probably would stay stock a-arms. Those grey plastic bulkheads must be much better than the original T-maxx black plastic (2003). Anytime an a-arm took a hit the bulkheads would break. I ended up with aluminum bulkheads and RPM arms. But the weight killed the performance of the 2.5 engine.
    I agree was a little impressed. When I had the brushless emaxx I would break something on every trip out. Eventually upgraded to, if I remember correctly, FLM bulkheads, skid plates and RPM A-Arms. After that it was pretty good. Well with the steel driveline as well.
    I知 sure at some point I値l start upgrading this maxx just because I get bored and like to tinker.
  2. #42
    Aug 2020
    Bay City, TX
    116
    Quote Originally Posted by mrtwohands View Post
    First breakage today. I swear I didn’t see the tree . Honestly surprised it’s not worse. I’ll bend the shock arm back into place.
    Which one: stock or RPM arms? I’ve ran RPM in the past on other models and thought they were a little too flexible
    Ouch! Amazed that's all that happened. Unless you own a machine shop I wouldn't bend that shock shaft back into place. You won't get it perfectly straight and you risk messing up hole in the bottom of the shock body.
  3. #43
    Aug 2012
    1,940
    I agree. Bending the shock shaft is only temporary until I decide to go big bore shocks or not.
    I致e done that in the past and it was good for a bit. I take the shocks apart and put the shaft on a piece of flat stock and keep at it to it痴 pretty straight.
    But I知 sure it weakens the metal some.
  4. #44
    Aug 2012
    1,940
    Yesterday was a tough day with the nitros.
    Revo fuel tank has a hole in it and needs to be replaced. Legit have no idea where it came from. Oh well. Easy fix.
    Tmaxx was not wanting to run right. Was running just fine the other day. The tune was all over the place and I couldn稚 get it sorted out before having to pack up. Guess I値l try again another day.
    It痴 all part of it but still stinks when you just wanted to bash. Might be time to add an electric for those type of days .
  5. #45
    Aug 2020
    Bay City, TX
    116
    Bummer. Assuming the fuel is fresh sounds like the T-Maxx might have an air leak. Make sure carb pinch bolt is snug. Just snug, not monkey tight. Look for signs of fresh fuel at the tank. Fuel tanks can crack at the seam. Might try a new glow plug if you’re still on the original.
  6. #46
    Aug 2012
    1,940
    Sealed off revo tank and submerged in water. No bubbles. I知 now assuming the kid wasn稚 sealing properly. Cleaned the tank and lid for a tighter fit. Well try it out again.
    Not sure it痴 bad fuel as the same fuel ran fine in the Revo. I will check for air leaks though.
    Maybe I am just rusty with tuning a nitro .
  7. #47
    Aug 2012
    1,940
    Got the revo back running right. When I added the longer fuel line I had the line ran the wrong way. Whoops. Had the carb line going to the exhaust. Still think I need to replace the fuel tank lid just to be safe as it doesn稚 seem to seal like it should. Even after tightening.
    Don稚 see any issues with the Tmaxx that would warrant tuning issues. With that said I think I値l try different fuel and retune from there.
    I did order some VP Master Basher 20%. Will see how it runs in these 3.3痴.
  8. #48
    Aug 2020
    Bay City, TX
    116
    Well, that would do it! For the Revo you can order just the o-ring. T-Maxx is the entire lid assembly. I know it’s new, but thought maybe you’d cracked something when you clipped the tree. Fuel tanks are notorious for developing leaks, just across all brands and all models. Shoe Goo works wonders in a pinch ha ha but I’ve never tried it as a long term solution. If the fuel is good in the Revo then it will be good in the T-Maxx so doubt that’s the problem.
  9. #49
    Aug 2012
    1,940
    Guess I知 back into the hobby
    Broke a tie rod today. Had fun till the Revo and Tmaxx broke. Both easy fixes and they were flying high when they broke...well until they hit the ground I should say
    Might take this opportunity to upgrade to the RPM True Track.
  10. #50
    May 2020
    Maine
    684
    Holy cow. How high was the truck?
    Now would be a perfect time to upgrade. If you buy the same stuff, you might as well buy 5 cause it'll probably just break again.
  11. #51
    Aug 2012
    1,940
    Do y誕ll recommend the true track setup? Figured it might be worth it to ditch the tie rods.
  12. #52
    Aug 2012
    1,940
    So before the truck broke the other day. I知 struggling to get this truck tuned on the low end. It still creeps on asphalt but not grass. Also when I pick it up off the ground the tires start spinning like crazy. I致e never had this much trouble tuning something.
    Took some pictures where it looks like there was some fuel or something coming from the front of the motor. So I thought maybe the clutch was dirty. What do you all think?
  13. #53
    Aug 2012
    1,940
  14. #54
    Aug 2012
    1,940
  15. #55
    Aug 2020
    Bay City, TX
    116
    Shouldn't be any fuel coming from the front of the motor. Is it idling high even though the carb gap is correct? That could cause clutch creep like you're describing and an air leak could cause that. This engine is new correct? So, I'd be surprised if you had a leaking crank bearing. Check the pinch bolt on the carburetor and make sure you don't have a tear in the air filter assembly. Possibly a tear in the fuel tubing but that's pretty rare. I think you'd already verified the fuel was good and the plug was new.
    If it's not idling high, then look at the clutch. Make sure it's shimmed properly so the clutch bell isn't hitting the face of the clutch. Could also be that the spring is just stretched. That happened with the T-maxx I'm rebuilding, but it was really obvious it was stretched when I removed the clutch bell.
  16. #56
    Aug 2020
    Bay City, TX
    116
    Looking at the pics it looks like there’s fuel/oil up on the carb. Make sure the HSN assembly is snug. Mine was actually a hair loose on brand new engine with 4 tanks through it. Not tight, just snug to make sure it’s seated.
  17. #57
    Aug 2012
    1,940
    Thanks for the tips. I will look in those.
    How would I know if the clutch is shimmed right? The only shim I have is the one on the outside under the E clip.
  18. #58
    Aug 2020
    Bay City, TX
    116
    I believe that's the stock configuration. Works great on my engine. Clutch shimming is a touch feely thing. You want a small amount of play, 0.5 mm or less. You also want the clutch bell to spin freely and not hit the flywheel or the front of the clutch. And you also want the clutch bell to be positioned so it engages all of the spur gear. The good news is that if you're running the TRX 3.3 engine the stock shimming should get you pretty darn close on all of them.
  19. #59
    RC Qualifier jdpasl's Avatar
    Dec 2014
    USA
    506
    Awesome posts, I am going to get T-MAXX this Saturday. Last week ago I got Jato 3.3. RC for Life.
  20. #60
    Aug 2012
    1,940
    Quote Originally Posted by cjtamu-redux View Post
    Good to know. Thanks.
    My clutch meets all of those standards. I知 going to clean everything up really good and check over it all again. Run it a few times and see what happens. Also going to put the carb back into factory settings. Especially now since I have a different fuel.
  21. #61
    Aug 2012
    1,940
    RPM True Track came in today. Will hopefully get it installed tomorrow and then I can address the idle issues.
