Results 1 to 28 of 28
    Aug 2020
    16
    Burning smell coming near motor
    So I just added new steel rear axles(eBay cheap version) and big foot wheels so itís much bigger and wider then stock. I test drove it hard in my garage for about 5 minutes and I get a burning smell near the motor. Does anyone know what is burning ? How bad will my car damage from this? Thanks in advance for anyone who can help.
    -Slash 4x4 vxl on 3s
    RC Qualifier Calebs0615's Avatar
    May 2020
    Maine
    590
    The biggest mistake I ever made was buying monster tires...
    To answer your question, you need to gear down to compensate for the rotational mass you added with metal shafts and bigger tires.
    The burning smell was likely one of the wires going to or from your motor to or from your esc. But if it still works, it should be fine.
    You should invest in a temp gun. I got one at harbor freight for like 40$. Dont operate your truck if your motor is over 150 or 160 degrees.
    Sent from my LGL722DL using Tapatalk
    Aug 2020
    16
    Can the wires be replaced? I have a temp gun the motor was only 112 after 5 minutes. I’ll be going back to stock wheels and return the axles. I recently snap the stock stub axle right after a new 3s battery. Would the oem Traxxas steel drive shaft have less weight and problems?
    RC Qualifier GotNoRice's Avatar
    Northern California
    565
    How bad was the burning smell? I mean it's normal for electronics to smell a bit when they get hot, and a motor can certainly get very hot. You said 112. 112F or 112C? 112F is not hot enough to make anything smell like burning though, and certainly not hot enough to burn a wire. Maybe if something was wired poorly, and you have arcing somewhere.
    You should not worry about the heavier tires or axles. Plenty of people run monster truck tires on their slash. Gearing down is a good recommendation. Long-term, you should probably consider a bigger motor. For example, in the new Hoss 4x4, Traxxas paired your same VXL-3s with the larger motor from the Maxx.
    Jun 2014
    San Gabriel, California
    8,277
    Was it an electrical smell? If not, could it have been your slipper? It may be too loose for your changes. If it was, you should probably take it out and check it for glazing.
    Good luck!
    Sep 2019
    203
    Gear down, You must.
    Or just do a 1/8 motor and esc
    If you only drove the truck for 5 minutes in your garage (probably 72-80įf) and it got hot enough to smell, how would it do outside in the heat?
    "Speed and power solve many things"
    Aug 2020
    16
    It smelled like burning rubber or some type of burned fluid. It was 112f on my temp gun. This truck is new so I ran it about 3-4 times everything is stock besides cooling esc/motor fans, rear steel axles and larger tires. Could it be the wires heating up or slipper clutch glazing?
    I think Iíll replace the tires with the stock. Is there a tire/wheel slightly taller but stock width that would work on the slash and not have problems?
    Sep 2019
    203
    If its the slipper clutch you could hold the ruck still and the motor should still spin
    Aug 2020
    16
    I held the truck the wheels spin normally. What am I looking for? The smell only happens when it’s being driven
    Sep 2019
    203
    Can a bad bearing make a liquid smell? Im guessing
    Theres not many liquids in the slash 4x4
    But i know a motor can make electric smells and burning smells AND liquid smells sometimes.
    I cant tell if it might be one of your fans blowing around a smell from the esc?
    And also i meant a burnout ish thing see if when the tires have a load they still try to spin
    May 2020
    Maine
    590
    Quote Originally Posted by Slashn4x4 View Post
    You might want to be checking different spots on the motor cause the top could be 120 when the barrel its self is like 180.
    Aug 2020
    16
    Yes around the motor and the back of the motor also the highest I got was 112. Could it be the 3 in 1 oil I put in all the axle bearings burning?
    Sep 2019
    203
    Hmmmmmmmmmm
    Check this bearing
    https://www.flickr.com/photos/189146...posted-public/
    [IMG] 20200813_115024_2.jpg[/IMG]
    May 2020
    Maine
    590
    I dont know, I wouldnt think theyd get that hot.
    Aug 2020
    16
    I will check that bearing tonight. Does it usually
    Burn up when installing bigger wheels and not gearing down.
    Sep 2019
    203
    Im not sure but i know that that one bearing can do some crazy things
    Also its the second fastest moving bearing so if its damaged something could happen
    Ive never had anything happen to that bearing before though
    Nor have i heard about it smelling
    But ive had one cease and i couldnt even hear it
    If you have the stock bearing there, could it heat up and burn up the rubber seals?
    Aug 2020
    16
    I need to do some research on install and reinstall of that bearing to check it. I did put on the original wheels ran it no burning smell. Then I put on the bigger wheels and I get a burning smell after a short run. The car is a lot slower with the bigger wheels also .
    Itís not worth doing a monster slash until I have more Info on what needs upgraded. Has anyone done a 4x4 vxl monster slash successfully?
    Sep 2019
    203
    Dont check that bearing, you dont need to if the smell stopped, its not that bearing. But i fear it IS the motor or the esc.
    One of those things do crave a lower gearing
    Maybe a pinion gear with 3 less teeth
    The bigger wheels put alot of strain
    Jun 2014
    8,277
    Did you check your slipper? Is it loose?
    Aug 2020
    16
    Not yet because of time. Hopefully soon. Did you have a similar problem?
    Jun 2014
    8,277
    No, I upgraded my slipper system when I went to the larger 2.8 wheels/tires.
    With increased rotational mass, the slipper would need to be tightened from stock settings to compensate. Worth checking. If you don’t want to take it apart, just tighten it and see if it makes a difference. Just keep in mind that it may have glazed your pads over by now and you may have to take them out and scuff them up.
    Good luck!
    Aug 2020
    16
    I haven’t taken apart the car yet but I pop off the cover and the smell it’s definitely the slipper clutch pads. The surface of the disc looks shiny still but the pads look a little deteriorated. Is it time for a rebuild yet if the truck drives fine? What other parts should I upgrade. I hear the bushing and bearing should be replaced because they go bad quickly .
    https://flic.kr/p/2jwo19U
    https://flic.kr/p/2jwsrsk
    Jun 2014
    8,277
    You can get new pads if you want (I like the aluminum ones) and upgrade to a metal bearing adapter.
    Just remember to tighten it up a bit. Test test test...
    Have fun!
    Aug 2020
    16
    Thanks Squeegie. U we’re right the whole time!
    Sep 2019
    203
    For me, that seems like a high pinion gear ratio for big tires.
    But if it works it woks lol
    Also when something goes wrong in your truck, just keep digging around until you find whats wrong
    And also if theyre not the aluminum pads, they should be scuffed right?
    Jun 2014
    8,277
    No problem! I’m just glad the source of the smell was found and that it is a free (if sanding/scuffing) or cheap (if replacing) fix!
    Have agreat weekend!
    Aug 2020
    16
    It’s the original pinion gear. The extra pinion gear that came with the truck is that the lower gear pinion?
    Sep 2019
    203
    Itís the original pinion gear. The extra pinion gear that came with the truck is that the lower gear pinion?
    I think thats the speed pinion gear that is a higher ratio
    Thats not good for big wheels 8(
    Sent from my LM-X420 using Tapatalk
