I turned on my truck to set steering limits. App forcede to do updates to transmitter and receiver. And....my truck is a brick. Did transmitter reset. Tried to recalibrate the esc. Esc wouldn't go into calibration mode. Chatted with Traxxas and now have to send in my esc, receiver, and motor. Not a happy camper at all.
I think the update went through. I'm on Android. But will try on 4g as opposed to WiFi.
In Android if I just turn off wifi. I have no issues. If wifi is on. It will take forever and then fail.
Can always try airplane mode as well. As I think once it shows update the file has already been downloaded. Just make sure to turn BT back on if on airplane.
Well. Somehow I got it working again. But...it will only work if I have the app on now. Kinda annoying....but at least it's working.
If the app isn't on, the esc flashes green. I get zero throttle, and zero steering. Nothing at all.
Try this https://youtu.be/ix-J85uRFjE
I've tried that a few times...but THANK YOU FOR MSKING ME WATCH THAT AGAIN!!!!! No....seriously. Everytime I've tried doing it, I think I've made a fatal mistake!! What I've done is, I've plugged in batteries, turned on remote, turned on the esc, then tried to go into recalibrate mode. Everytime, it done nothing except turning off low voltage shutdown after holding the button for 10 seconds. I need to try it again and press and hold the button BEFORE turning on the esc. Maybe I'm a complete freaking idiot!!
Sometimes it's the little things. Esc flashing green means it needs throttle calibration.
I'll give it a shot. I'm sure you're right though!! This is why I joined and love this tiny little community of erevo bashers!!! Thanks again. I'll report back in a few hours, after I get the chance to try that.
Big thank you goes to acidic!!! My truck is back to normal and was only bricked in part due to me not being able to follow simple instructions!! Super relieved that I don't need to test it apart and send stuff in!! Thanks again acidic.
I don't have a clear answer, just my educated guessing.
I couldn't get my truck to update when I got my bt link 2y ago ago. And it would stall out it would run for 2 to 3h before I would just shut it off and want to use my phone again. The link app forces you to update if there is a update. So i was stuck in this constant update loops. And since half done truck unusable.
In searching for a answer. I found someone saying to put phone in airplane mode. Before starting update.
And low and behold that worked.
I'm sure the update file is less than 1mb perhaps a little more... Don't know what kind of eeprom / flash memory it tx/Rx/ esc has but it's probably like 50kb for file size. Or even less So downloading over wifi or 4g /3g really doesn't matter. I tried to find the files it may use but I couldn't figure out what folder it went to with just a quick searching.
The issue is probably something with the phone wifi module messing with the tx BT link signals or some software bug. BT and wifi run off 2.4ghz frequencies so I would almost bet the phones wifi signal is so much stronger than tx BT that it creates some errors in updating. Or some kind is signal interference. When it does a update with wifi on or cell service on. During Validation of the new firmware update and if any errors it's freezes up. And trys again. And gets stuck in a update loop. But again could totally be software.
I have never gotten a update to work with wifi turned on with my Android phone.
I hear iPhone users have to be in airplane mode. But again may just be wifi off.
In either case by time you get to the update portion of the link app. The files it needs are downloaded. So out into airplane mode with BT on and things work...
