    Aug 2020
    Default Stampede VXL 4x4 Hobbywing 4000kV Upgrade
    Hi everyone, Recently bought this Max10 SCT ESC Combo with 3660SL 4000kV Brushless Motor for my pede 1/10, but when I installed it it broke the spur gear of the slipper clutch, probably the gear of the motor didn't fit on my current spur gear.
    Now I have to buy the slipper clutch and a different gear but don't know what to buy, can someone help me get the correct parts?
    Thank you very much for any information.
    Pictures: https://www.screencast.com/t/WbLaIv55xtw
    -The gear is bigger than the original engine
    -The gear broke the spur gear tooth
    -Also the pin of the engine is thicker for the hobbywing
    Northern California
    597
    Quote Originally Posted by fredix View Post
    You don't have to buy a new slipper clutch, you just have to buy a new spur.
    https://traxxas.com/products/parts/telemetry/3956
    https://traxxas.com/explodedviews/67...ampede-4X4-VXL
    For your pinion, you need 32-pitch (often abbreviated as 32p) or Mod 0.8. Mod 0.8 vs 32p is metric vs non-metric, but they are so close that they are compatible. From the pictures, it looks like you tried to use a 48p pinion gear (smaller teeth). You will also need a pinion that can fit a 5mm shaft.
    I would recommend this:
    https://www.amazon.com/Robinson-Raci.../dp/B00JNL5UVG
    Keep the teeth count lower IMO since 4000kv is pretty high, especially if you ever want to use 3s lipo.
    Dec 2003
    Dekalb, IL
    3,265
    Yep, your going to want to run a pretty low pinion.
    When I ran the max10 sct/3660sl 3200kv in my stampede, mine overheated the motor on me running 13/54 gearing with trencher 2.8 tires on 3S. I never ran 2S in it, so not sure what gearing you'd need to run for that.
    When I ran the castle sct sv3/3800kv, I was able to run 11/54, but it was cooler out at the time, so not sure how it would have done in the summer heat. It was 35-40F outside at the time.
    When I ran that same system on 2S, I ran 13/54 and it did ok.
    I had fans on the esc and motor.
    So, to run 3S, you may have to try and use 10T pinion and with 2S, a 12T pinion. Unless your running the stock tires. I think they are a bit lighter and lower profile than the trencher 2.8's I ran, so they will put less load on things.
    I run in the grass a lot, so I have to gear for that.
