I have a trx4 defender with traxxas lights (headlights and light bar).
I went and picked up a brushles system for my trx4 but it doesn't have the external red plug (needed for the light kit, Fan, BEC, other accessories). Can i solder it on the connector or how sould i try to solve this.
Any tips are welcome.
Thanks in advance.
yes, solder it. any aftermarket electronics will basically require soldering.
solder the lights to the input wires of the esc it runs off direct battery voltage
Be careful, as i hooked up my Traxxas trx4 light kit up per directions, worked great for ~2 months now....
Fast forward.
I installed a HW 1080 esc into my 'rex, did great, spent a few days playing outback on my crawler course, running back into garage, using program card to change settings, rinse & repeat...i decided two days ago to just "try" setting BEC voltage to 7.4V to see how my hexfly servo (4.7-6.4V rating)** and within seconds, i actually BURNT OUT MY dang traxxas headlights! (I had the jumper set to "brights"...boy, they didnt like it, so now im reduced to my LED lightbar (which is crazy-bright), and the front marker lights (Traxxas kit) (amber), and the tail lights still work Thank Buh-jeebus! Lol! Im ok with it for now, and def. Learned a lesson in over-volting, which i normally know better, smh.
Long story short, dont supply too much power to your smaller LED's, they dont like it! Im not sure, but i my brain tells me if you wire straight to batt voltage @ 3s (11.1+V), you may at the LEAST have long-term issues with the headlights? Anyone, feel free to correct me if im un-educated, as i heir on the side of caution now with all my RC electrical
Sent from my Pixel 3a using Tapatalk
I’ll second your advice. I had my blazer light kit and my rock lights hooked up with a jumper to the battery. Everything worked great until I decided to try out a 3s battery. Plugged it in ran for a few minutes, noticed a headlight burnt out. Didn’t think much about it. Figured a I pulled a wire or something loose. Kept running then saw smoke coming out of a couple of wheel wells. Sure enough my rock lights were burning up.
If you run to the receiver, it will be your safest bet. The esc's Bec will supply the rx with less voltage than running straight to the battery.
Sent from my moto e5 cruise using Tapatalk
Ya can't polish fertilizer...
@Trx4newb and @PFongemie: Where you using the power supply? The Traxxas power supply (part#8028) regulates the voltage down to 3v and is suppose to be used with their LED lights.
