Results 1 to 22 of 22
    Jul 2020
    24
    Pulled 3.3 Motor, mystery parts... help identify?
    I pulled the motor to replace a slipper clutch and when I did these parts fell out and I am trying to locate where they go.
    hmm, I thought I could post images here.. well, 1 part is a small black spring about 1/2 inch long and 1/8 inch in diameter.
    The other are 2 round silver washer looking parts with rough edges, about 1/4 inch in diameter. Those 2 appear to function as a lock washer of sorts.
    - If anyone can help me figure out how to post images, that would be great!
    Thanks in advance!
    Dec 2014
    Adirondacks
    2,115
    Quote Originally Posted by jfobel View Post
    Thanks in advance!
    The small black spring could be the spring for your clutch shoes. The other lockwashers could be to the 4 engine mount screws. If you have an RPM sensor it was probably on that side with those 2 screws.
    You need to use a picture hosting site. If your using a mobile device I read that Tapatalk is the way to go. Desktop I use the BB Code.
    Aug 2020
    Bay City, TX
    117
    There’s a Picture Tutorial sticky in the Traxxas Alley section.
    14,184
    Do you have the exploded views of the engine? If not download them through the Support button above.
    RC Champion mrtwohands's Avatar
    Aug 2012
    Warner Robins, Georgia
    1,942
    Could the black spring be the throttle return spring possibly?
    I agree small washers seem like the motor mount screw washers
    Jul 2020
    24
    Thanks guys, appreciate the feedback. Will check out the sticky and the diagrams.
    Jul 2020
    24
    Star washers - https://traxxas.com/sites/default/fi...gn%20mount.pdf
    ..still looking into the spring.
    Dec 2014
    Adirondacks
    2,115
    What kind of ends are on the spring? There is throttle return spring,brake spring,clutch, and if you have a spring mount header. Each with a different style.
    Jul 2020
    24
    There are actually no ends on the spring, at least not like the throttle return spring. Looks more like the spring connected to the transmission for forward/reverse. The one with the plastic gear looking at the end of the shaft. I didn't remove that one so I know that's not it.
    Clutch spring? I installed the rebuild clutch kit just now and didn't see anything in the documentation about a spring.
    Dec 2014
    Adirondacks
    2,115
    Here is fwd/reverse spring:https://traxxas.com/products/parts/5392
    Like that spring?
    14,184
    The clutch on the engine consists of two shoes and a spring. The spring gets wound around the shoes and best practice is where it connects to itself should not end up by the pins.
    Aug 2020
    Bay City, TX
    117
    Don't know why none of us posted this. Here's the clutch spring.
    https://traxxas.com/products/parts/4146X
    Jul 2020
    24
    I don't think I dug into the truck that far because neither of those parts look familiar at this point.
    I am going to close this thread because I cannot find anything about the spring. Going to re-assemble the truck, set the slipper clutch and spur gear and take her easy and see how she feels.
    Thanks again for ya'lls help.
    Dec 2014
    Adirondacks
    2,115
    Would it happen to be the extra spring (not used on the revo) from the slipper clutch rebuild kit? Part#5352X
    You've got us curious,LoL.
    Aug 2020
    Bay City, TX
    117
    Yep. Because ideally, when you pull the engine, springs and washers are not supposed to fall out!
    14,184
    Could be the external piston return spring.
    Aug 2020
    Bay City, TX
    117
    Maybe. Or a blown muffler bearing
    Dec 2014
    Adirondacks
    2,115
    Quote Originally Posted by cjtamu-redux View Post
    Yup. Those pesky muffler bearings are tricky.
    RC Qualifier NitroBugg's Avatar
    May 2018
    MS
    326
    Could it be the shorter break spring in this kit?
    https://traxxas.com/search?keyword=5368
    Oct 2020
    3
    30 weight Ball bearing grease... Say's my buddy Fletch
    May 2018
    MS
    326
    Quote Originally Posted by jonny uptown View Post
    I would check the headlight fluid too.
    Aug 2019
    127
    Quote Originally Posted by NitroBugg View Post
    Doubt it, I think it would sooner be the blinker fluid. Due to the constant blinking the fluid goes bad faster.
