Results 1 to 12 of 12
    N. Idaho... Da Sticks!
    8,081
    Project: M8 TRX6
    New project time... Just got the first part to my TRX6-based M8...
    Untitled by Scott O, on Flickr
    May 2020
    88
    What is that exactly?
    Sent from my SM-G986U using Tapatalk
    Jun 2017
    Belgium
    206
    I don't know what the M8 stands for, but I think I've seen that crane before.
    15,587
    8x8... How many axles will steer?
    Sent from my moto e5 cruise using Tapatalk
    Ya can't polish fertilizer...
    RC Qualifier TITANIUM94010's Avatar
    Sep 2019
    San Francisco CA
    458
    Not sure what you meant by M8, but this is undoubtably going to be a great build!
    Are you reffering to the Swiss Sauer M8? Or a military 8x8 like the one pictured above?
    I'd love to see how this turns out, good luck!
    Jumping: maneuver and pray it won't break.
    Feb 2020
    1,217
    Hope to see the results soon.
    8,081
    Well, here is the second part...
    The detail is amazing. I am even more amazed it arrived in great condition, it was sent in a plastic bag, with not protection at all.
    Man, I was Traxxas sold the TRX6 as a kit, with no body or electronics...
    Oh well, I have abused my TRX6 body, and will need replacing soon.
    Feb 2020
    1,217
    This project is outstanding.
    Jun 2017
    Belgium
    206
    I think I've seen that cab before
    A TRX-6 kit would be nice.
    8,081
    Finally got caught up on my school work, and carved out a little bit of time to work on this project.
    First, I ripped apart an old servo and turned it into an ESC. It works great, the next step is figuring out the resistance balace between the two directions so I can replace the pot with resistors. I think it is 2.5kohm on each side, but I need to play with it to find out.
    Next, I used the ESC to figure out what channels are what on this thing, thankfully, after the multi-ESC circuit, the wiring is straight forward. I was a bit surprised, the wiring going into a slip-ring, so I do not have to limit rotation at all.
    If you are interest, here are the colors:
    Blue/Yellow: Winch
    Purple/Green: Boom in/out
    Black/Red: Back lift (single)
    White/Orange: Front Lift (dual)
    The little board on the base is a 5 ch ESC, that gets power and signal through what looks like a standard 3-conductor servo connector. Given that I have no plans of buying the radio needed to run this guy, it will find its way into a landfill via my trashcan; after removing the servo lead, of course.
    At a tipping point between deciding if I am going to rip apart five servos for their controllers (will use the rest of the servo as a servo winch), or just get five HW1060s. Given that this thing runs off of 30awg wire, I am leaning towards the servo controllers.
    8,081
    The first speed control is built and tested, four more to go. I also have to design cases for them... fun stuff!!!!
    Untitled
    8,081
    I am making slow, but steady progress on this.
    I have four of the five ESCs wired and installed, #5 should come in sometime around the end of the week. These are all getting wired up to a DX6e six channel RX, and will be powered off of a CC 2.0 BEC fed off the main battery.
    I designed and printed the ESC tree and stand, a cover that looks like a GENSET will go over the top of it. The GENSET has working doors that line up with the pots for easy access for adjustment!
    In case you are wondering...
    P = Pedestal (the base at the bottom)
    W = Winch
    B = Boom (extend/retract)
    RS = Raise Single
    RD = Raise Double
