Results 1 to 13 of 13
    Jan 2020
    Phoenix, AZ
    122
    Which is worse...?
    I charged my 6500mah SMC 3s last night. I may drive the truck tonight, but I'm letting my brother borrow my charger. Is it worse to leave it fully charged until Monday (when I'll get my charger back) or leave it fully discharged until then? Thanks!
    May 2020
    Maine
    687
    I would say if you can put it in storage mode, that's the way to go. But id leave it discharged. In my opinion.
    Dec 2003
    Dekalb, IL
    3,265
    Leaving a pack fully charged is hard on it. Doing it once likely won't hurt it much, if at all. Lipo's IR tends to go up when left fully charged for long duration's.
    The issue with discharging it fully (to LVC/3.2-3.4V) and leaving it sit is that it can potentially self discharge below a safe level which is why we store them at 50% charge.
    May 2020
    Maine
    687
    So the best thing to do would be set to storage and then let it sit in storage mode?
    Dec 2003
    Dekalb, IL
    3,265
    Always, if you don't intend on running it in the next 24 hours.
    May 2020
    Maine
    687
    What about setting to storage mode until its at storage volts and then unplugging and letting sit?
    Dec 2003
    Dekalb, IL
    3,265
    Quote Originally Posted by Calebs0615 View Post
    That's what your supposed to do if your not going to use them.
    Dec 2014
    Adirondacks
    2,111
    You should unplug the battery from the charger. It's never a good thing to leave a battery plugged in after it's done charging, discharging, or storage mode.
    May 2020
    Maine
    687
    Thank you guys for clearing that up for me. if it was on storage charge id just leave ot on the charger. In storage mode of course.
    Dec 2014
    Adirondacks
    2,111
    Don't leave battery plugged in.
    May 2020
    Maine
    687
    Isn't that what you both just said?
    Dec 2014
    Adirondacks
    2,111
    Sorry if I mis-understood. What you wrote read like you leave the battery connected to the charger after storage charge was completed.
    ...if it was on storage charge id just leave ot on the charger...
    I took it as you put the battery on storage mode on the charger and you wouldn't touch it again until you went to use the battery again.
    Jan 2020
    not in an ocean
    246
    Also, your charger will last longer if its not plugged in for long amounts of time. Less hours of use on it.
