Results 1 to 16 of 16
    May 2020
    Maine
    795
    2wd Slash Tire Recommendations
    Im in the market for a new set of 2.2 pre mounted tires and wheels.
    Im looking at getting the Duratrax Sixpack tires and wheels from amain. I don't want the stock bfgs that come on the truck just because they wore out so fast it seemed like..
    Edit: I should probably add in that i drive mostly on low grass and dirt/gravel.
    Apr 2015
    1,122
    The Sixpacks would be a great Tire for your driving conditions.
    May 2020
    Maine
    795
    Thank you. I was looking at the tread on my badlands and i loved how those grabbed. I wanted to get something close to that. I was also thinking about just getting a smaller badland but i want something different.
    Sep 2012
    Hammonton Nj
    894
    2.2 sandpaws on rpm wheels, love them have three sets, last forever, dont really balloon, great in dirt , grass , sand ...
    I do balance them for sure , the take some work though, gluing , balancing ... put holes in them to let dirt out....
    May 2020
    Maine
    795
    Im not sure about a sand paw.. I just think thats too aggressive. I do drive on most every terrain including tar and cement.
    I feel like they'd wear quickly. But to have a set on hand would be nice for snow and what not.
    May 2006
    Murfreesboro TN
    350
    its a shame you cant get Geolanders anymore, Ive been reluctant to thrash the only set I have, luckily they have held up well for the past 12 years.
    May 2020
    Maine
    795
    12 years!? Thats awesome.. Is that with 3s?
    May 2020
    Maine
    795
    If i buy front tires for a 4x4 truck on all four corners, wont it give me a small offset?
    Aug 2015
    778
    4x4 front and rears are the same as 2wd rears. The 2wd fronts have more offset. Using 2wd fronts on a 4x4 will give you a wider track.
    May 2017
    104
    if you want a good set of tires the majority of people will say badlands but i find they go bald way to quickly and they wreck ur body to much from the lugs which happened to me on my 4x4.
    it also depends what your driving style is if u like sliding around on gravel or short grass or even dirt and road go with something that has more of a road pattern, such as gladiator tires from proline.
    Or if you like having lots of grip go with trencher X from proline which have wider lugs and more aggressive and will grip more.
    IF you get trenchers you'll understand the name
    Another good set of tires is duratrax lockups which have a very aggressive tree pattern either tire would be ideal. Its all about trying different things to see what u like
    604Slash 4x4
    Gone Bashing
    May 2020
    Maine
    795
    Quote Originally Posted by dgechrgr469 View Post
    Oh sheet. My truck is 2wd. Oh well. Thank you.
    May 2020
    Maine
    795
    Quote Originally Posted by 604Slash4x4 View Post
    604Slash 4x4
    Gone Bashing
    My bad lands have barely worn. Ive been bashing with them for probably 3 or 4 months now and i still have atleast 75% tread. You can see the nubs in the lugs still.
    And yes thats kind of why i want to try a different tire. Just to see what kind of difference it will make.
    May 2020
    Maine
    795
    This is what im going with. 2 sets of these. They're fronts so i should have the same offset all around right?
    I know I said I wanted 2.2s, i know these are 2.8s. They're almost half the weight of a belted badland so im hoping i wont have a big axle issue like before.
    May 2020
    Maine
    795
    Sorry i keep posting but i keep finding out more info. I figured out that they have a "MT" or an "ST." The MT is 2.6 inches wide. And the ST is 1.9. Im thinking if i get that big wide MT its going to rub bad and or keep breaking axles. I'm for sure staying with the ST.
    Aug 2015
    778
    Quote Originally Posted by Calebs0615 View Post
    No problem, just wanted to make it clear.
    May 2020
    Maine
    795
    I very much appreciate it. I would hate to buy a set of tires and have the front or rear stick out further than the other.
