Thread: 4wd Drag
    Aug 2020
    Kansas City
    130
    4wd Drag
    Are there any 4wd drag chassis out there? I know you don't want 4wd for drag racing, I just want it for the aerodynamics in a speed running project.
    May 2020
    Maine
    691
    Is this something like what your looking for?
    14,184
    The Slash 4x4 LCG has proven to be very versatile and many have used it for speed runs. If you want something bigger then go with the XO-1.
    Aug 2020
    Kansas City
    130
    Thank you both. I think I will need to use something like that chassis for figure out how to do the 4wd setup. Good learning experience.
    Aug 2015
    737
    I think that chassis is for the 2wd Slash. I have not seen one made for the 4x4. Most of the r/c drag racing is centered on the 2wd, until 4x4 drag racing becomes more popular the choices are limited although a group I belong to in northern IL has a 4x4 drag class. Lower it as much as possible and find a aero body, same as your speed run car.
    Northern California
    597
    You could always make a 2wd drag racer using the Rustler 4x4 or Slash 4x4 platform. Simply omit the center drive-shaft, the front differential, and the front drive shafts. You get the built-in benefit of having the motor in the center instead of the rear, without having to do any mods.
