Results 1 to 13 of 13
    Mar 2020
    24
    Question TRX-4 JX ecoboost servo surges bec system
    Hello, I'm having an issue with my TRX-4 sport where when I'm crawling the servo is insanely weak and surges the whole BEC/receiver system when it stalls and causes the shifter servo to twitch and shift into neutral. I've installed the RadioLink RC4GS controller and receiver so I could shift with endpoints set and I have the Traxxas BEC to feed it more power and I also have installed a traxxas velineon system for more speed. The servo is the JX Ecoboost 21kg. If anyone knows the reason please tell me how to fix it. I'm thinking the issue may be the receiver not being able to distribute the power and causing it to surge.
    https://drive.google.com/file/d/1Y1S...ew?usp=sharing
    Jul 2020
    5
    There are no readily available info on that servo as to how much amp draw it has. Isn't the traxxas bec only 3A? It may be not enough for that servo.
    I have the same in my Arrma granite and it's fine but the stock esc has a 4Amp bec built in.
    I don't know if anyone like rc review or exocaged have had one on their servo test rig to measure amperage?
    Sent from my Pixel 2 XL using Tapatalk
    Feb 2020
    1,224
    Quote Originally Posted by Reddley View Post
    Mate, you need a high amperage BEC, and if your RX can, put the servo at 7,4v, is better overall.
    Oct 2018
    247
    How do you have it wired? Your bec should be powering your steering servo only, and let your esc's bec power your reciever and other servos. But as others stated, the Traxxas bec most likely isn't enough.
    Dec 2014
    Adirondacks
    2,126
    I would get a different external BEC as the Traxxas one is rated at 3amps. The Vxl-3s has a 2.5amp internal BEC. That's only .5amp difference between the two, not worth even installing the Traxxas BEC. Also with a different BEC you could run higher voltage to the servo to gain more servo torque.
    Feb 2020
    1,224
    Totally agree with this.
    Mar 2020
    24
    Quote Originally Posted by Steve g View Post
    As the Traxxas guide instructions say to wire it is how I ended up doing it. I plugged the BEC into the jst on the side of the esc and the esc bec wire into the output of the BEC and the input wire into the reciver on channel two meaning that the BEC is theoretically feeding everything 7.4v which didn't sound right to me but its the only way that works with the traxxas BEC. How I thought you should do it was you plug the servo into the output of the bec and the input of it into channel one but that didn't do anything.
    Mar 2020
    24
    I'm planning on getting the Castle BEC, it can run at around 10A with changeable voltage with my Castle link. Is that one any good?
    https://www.amazon.com/Castle-Creati...0047341&sr=8-5
    Dec 2014
    Adirondacks
    2,126
    Castle Creations is a good brand. That one will work, but remember that it is not waterproof. Castle also offers a waterproof one if you play in water/mud.
    N. Idaho... Da Sticks!
    8,082
    Recommend this one:
    https://www.amazon.com/Castle-Creati...s%2C266&sr=8-2
    This is waterproof, so you can mount it anywhere. Just check the voltage range of your RX, make sure it can handle the voltage you want to run.
    Feb 2020
    1,224
    Recommend this one:
    This one is better overall.
    Mar 2020
    24
    Recommend this one:
    Thanks, This one programable with the castle link? I just happen to have one for other vehicles.
    8,082
    Yup, with the field link, USB CastleLink, or the Bluetooth link.
