Results 1 to 20 of 20
    Sep 2020
    20
    Weak steering XMAXX, need help figuring it out.
    Hello!
    I've had my XMaxx for a week now, as of 9/14/2020. It's got roughly 4-5 hours of run time on it, mainly high speed passes and a couple jumps, but nothing like you see on youtube.
    With fully charged batteries (Traxxas XMaxx batteries) my XMaxx on the ground at a stand still in grass that's about 1.5-2" tall, my XMaxx will only turn roughly 25% of the way to the left. When I turn it to the right in the same setting, it turns full right just fine.
    If I pick the front wheels up, it turns full left and right just fine, no issues, no clicking sounds, no sounds of struggle, it sounds perfectly normal.
    While driving, at a higher speed, the vehicle struggles to turn left, but turns right at the same speed just fine.
    I've visually inspected all around the front of the vehicle and haven't found anything out of the ordinary. Everything seems to move freely and no binding either by using the servo to turn the wheels, or turning them by hand.
    Anyone else had this issue? or have any information on what it might be?
    Thank you.
    Mar 2020
    Portland, Oregon
    87
    The stock servos usually go out pretty quickly. Some people do not even test them and change them out. If i were to upgrade right now i would go with the 2085X.
    May 2020
    21
    I thought I had a bad servo too, but you might just need to do the nut trick on the servo saver. Mine came loose and i had terrible steering. On the sporing side of the saver theres a bolt runs through holding the 2 halves together. You need to add a nut to the bottom. If you search youtube theres a few videos on it
    Sep 2020
    20
    Quote Originally Posted by NitroRusty123 View Post
    yes yes, I read this and was hoping I'd get a bit more play time out of it before I started having issues xD Thank you for your 2nd response on my 2nd post xD you're quite helpful around here!
    Sep 2020
    20
    Quote Originally Posted by amihal View Post
    Yea that's something I'm definitely going to check on the truck. I'll probably dig into it this weekend and see what I can find. I don't know how it's all set up in there, and how the spring works 100%, so it's hard for me to understand how that nut coming loose would cause it to be weak in one direction, and not the other.
    But that is definitely something I'm going to look into and need to find where I can find the proper bolt and nut to do it xD
    May 2019
    223
    Buy a new servo. 2085x
    Sep 2020
    20
    oh I have an idea, I'm going to look at this, this evening. That little linkage that connects the servo horn? I guess? to the servo saver, the plastic one that gets replaced with metal with the high torque servo, when the wheels turn left, that gets pushed to the right, so if it's being compressed instead of pulled on, that could be why. It could be that it's bending and not transferring the power from the servo to the servo saver and then the wheels!
    Will see what I find when I get home this evening
    Mar 2016
    1,400
    The stock Xmaxx servo linkage is weak -
    it bends like a banana
    The Maxx servo saver is stronger 8947
    Hot racing Aluminum linkage works
    Atomic aluminum servo saver for the fix
    2087X metal gear servo set for the stock servo
    fabricator
    Aug 2020
    42
    I did this before I even ran the truck for the first time.
    I also upgraded to the 2085X. I’ve read plenty of bad stuff about it but it’s healed up great so far.
    Set all the trim, endpoints, and % through the app and you should be all good.
    Aug 2020
    42
    I’ve read of the piece that supports the servo saver from the bulkhead breaking and causing some steering issues. But I’d imagine that would take some serious abuse.
    Definitely check that screw and replace it with a longer one and nut.
    Feb 2020
    Morristown, NJ USA
    211
    I agree check this first. Simple fix.
    Kevin Talbot how to: https://www.youtube.com/watch?v=ZufRihDGryw
    Sep 2020
    20
    Thanks for all the replies! I checked my theory out and unfortunately it seems that would hold true if it were an issue turning to the right, since that link is squeezed between the two parts under a right turn. When turning left, it's pulled on. Soooo I guess I'll have to do some more digging. Maybe pull the front end off to get a better look.
    Will definitely check out Kevin's video and do that as well. anything to make it more reliable is good xD.
    Feb 2020
    1,747
    Quote Originally Posted by x96mustanggtx View Post
    ¿Do you try to turn off the TSM?, try it.
    Sep 2020
    20
    Yes, you are correct. I popped the body off and everything seemed fine for the first couple turns, then I guess the tired dug into the carpet enough to provide enough resistance and I could see the servo saver raising up off of it's seat. So I guess that nut came loose or stripped and will have to be repaired with the added nut on the bottom, or replaced all together.
    The hot racing servo saver looks pretty xD
    Aug 2020
    42
    I’ve read more people having issues with the aluminum one not working properly when dirty.
    You’re going to see the servo saver rise up and compress the spring. That’s what gives to help protect the servo.
    I don’t think you’ll be able to tell if that screw is an issue until it is taken apart.
    Sep 2020
    20
    Quote Originally Posted by c7aea View Post
    Yeah, I watched Kevin's video and I'm trying to find out where I can find a longer screw to use lol. I only have my XMaxx and a Stampede 4x4 I bought to let kids play with. no luck so far D:
    Aug 2020
    42
    I got mine (and the nuts) at Home Depot. It was a couple bucks for a 3 pack. Any local hardware store should have them.
    I used one of the other ones in the pack along with some JB weld to fill in the hole in the bottom side of the bulkhead for the servo saver. Another one of Kevin’s recommendations.
    Sep 2020
    20
    Thanks! I'm ordering 3 packs of the screws, and 2 packs of the nuts lol... in case I come across anyone else that needs to do the same, I'll have some spares $4.06, not a bad fix!
    Just need to pick them up tomorrow and put it all in, hopefully adjust the servo saver properly lol and be good to go!
    Aug 2020
    42
    It doesn’t require any adjustment. Just tighten it down all the way.
    I have the 2085X which comes with the stronger spring but if you’re brave enough you could try to shim the stock one a little like in the video too.
    Sep 2020
    20
    I do want to look into upgrading the servo at some point, if I can keep this one going a while longer and for just a few bucks, great! I think I'll leave the tension alone for now xD unless it continues to cause troubles in the future, then I'll look into shimming it a little bit. Thanks for all the replies!
