Results 1 to 10 of 10
    Sep 2020
    5
    Problem with my front wheel on my newly built trx-4 chassis kit
    Hello ALL,
    I recently purchased trx4 chassis kit (this is my first ever RC I built) and I was able to finish it. I wanted to have a defender body shell so purchased the conversion kit and installed it as well.
    The issue I am having is when the front wheels are steered completely to either left or right and give it some throttle the wheels are spinning as if it is losing a spin in between. Under higher throttle, the wheel spins in the same way and I do I hear a little rattling sound.
    I do not see the issue when the steering is straight or steered up to 70% left or right.
    The link shows the issue i am talking about.
    https://www.youtube.com/watch?v=a7JEDYDaWCk
    Any suggestions will be appreciated.
    Feb 2020
    1,220
    Quote Originally Posted by nisanth_kom View Post
    Hello ALL,
    The issue is the front wheel hubs, it rubs when the steering is in his maximum.
    N. Idaho... Da Sticks!
    8,082
    WELCOME TO THE FORUMS!!!
    This is normal, the steering turns sharper than the u-joints like, causing a bit of cogging in the drive train.
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    674
    Yep, that's happens on nearly all the TRX-4s that I've seen. Both of mines had the same problem. The only way to prevent this from happening is to set the steering endpoints, but it does remove some steering angle. I only go into full lock on the steering only if I have to.
    Sep 2020
    5
    Quote Originally Posted by Juanmacine View Post
    Thank you for the response, any suggestions on what can be done to fix the issue.
    I did take apart all the front axle assembly and verified, but couldn't find anything. Any ideas will be great.
    Sep 2020
    5
    Thank you for the response. Doesn't this damage the front axel or the portals or the gears in the axel? Any thoughts on it?
    Sep 2020
    5
    Thank you for the response. Yeah, I really do not want to lose any steering angle unless I have to. I wish it can be fixed without losing any steering angle. Any suggestions would be great.
    8,082
    The engineers at Traxxas opened up the steering as far as they could, but it is just a little too far for the u-joints not to bind. If anything, think of this kind of like a steering overdrive in that it gives you just a bit more throw if you needed. For the most part you will likely not notice it when you are driving.
    Feb 2019
    California Bay Area
    674
    A bit of grease would make it smoother, and yes, like Greatscott said, you most likely wouldn't notice when you are driving.
    Feb 2020
    1,220
    My suggestion is to limit the steering final points, as RCWilly says.
