Results 1 to 25 of 25
    Sep 2020
    13
    1/16 e revo vxl 2-3 minute runtime
    hey guys im fairly new to rc, about one year in and for some reason my merv's runtime is only about 2-3 minutes. its the same for both 2s lipos that I have. i dont run them together. today i got a hobbywing esc and it is great but it still only last about 2-3 minutes. i am not overgeared whatsoever. could it be my batteries? charger? please help.
    Jun 2014
    San Gabriel, California
    8,391
    How is your gear mesh, axles and bearings? Any binding can create extra load on your system. Make sure you have no extra resistance while rolling.
    Good luck!
    Sep 2020
    13
    I have recently checked my bearings and cleaned them out, my gear mesh is set correctly and the axles are fine.
    Dec 2014
    Adirondacks
    2,135
    Do you have a way to check the voltage of the batteries? If your runtime was 2-3min with the old ESC and then you still get 2-3min with a new ESC, I would say it's your batteries or charger.
    Sep 2020
    13
    how could i check the voltage?
    Sep 2020
    13
    the batteries that i use are 7.4v 1500mah 2s lipos.
    Dec 2014
    Adirondacks
    2,135
    Does your charger display the voltage? What happens when the 2-3mins are up? Does the ESC say low voltage or something else?
    Sep 2020
    13
    i have a crappy 5$ charger when the red light goes off on the charger the charge is done lol.
    Sep 2020
    13
    i do know that a red light was flashing on the old traxxas esc when it stopped
    Sep 2020
    13
    also the charges do seem half as long as they used to. i guess that means its the charger?
    Dec 2014
    Adirondacks
    2,135
    Bad batteries will do that too. Without a way to check the voltage it could be either.
    To see if the charger is bad you would need to know what the battery voltage is before charging and then after charging. A charged 2s LiPo would be 8.4volts.
    Sep 2020
    13
    could i use a multimeter?
    Dec 2014
    Adirondacks
    2,135
    Quote Originally Posted by ninjaluke16 View Post
    Yes. That would work great.
    Sep 2020
    13
    ok i will try that tonight.
    Aug 2020
    86
    I'm certainly no battery expert, but a cheap charger & Lipo batteries is a disaster waiting to happen.
    Balance charged Lipos can last for ages, but if not balanced charged properly & then left flat after use as opposed to being charged to a sensible voltage before shelving, you're just gonna kill em.
    I'd guess your batteries are getting tired due to the charger.
    Sep 2020
    13
    I used the multimeter. both the batteries were at 8.4v.
    Jun 2014
    8,391
    Can you set the LVD levels on the ESC? Maybe it’s set too high?
    Dec 2014
    Adirondacks
    2,135
    I'm thinking your batteries are bad. Is your ESC going into Low voltage protection?
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,417
    I have found these little devices real useful to get a general idea of battery level plus many other uses in projects.
    https://www.amazon.com/RioRand-Hop-u...436605&sr=8-20
    Seeing what the voltage is at varies times during your run lets you get an idea of how your model consumes its battery. If you can mount it in the vehicle you can even use it to see the voltage drop while on throttle which can indicate a faulty battery.
    These won't replace a multimeter because they just are not that accurate but good enough for when the meter is not around or you don't want to damage it. Plus these also display each cells voltage like a slideshow. Pictures timed to display total voltage from this 2s battery not fully charged.
    Dec 2014
    Adirondacks
    2,135
    I forget about these little devices. They would be perfect for issues like in this thread (and others), checking voltage while in use as a diagnostic tool.
    Jun 2014
    8,391
    Sep 2020
    13
    Cool. I'm Canadian but i know where i can get one. thank you so much guys. One thing I forgot to tell you guys is that the car takes a long time to slow down like a rolling stop.
    Sep 2020
    13
    ok in canada the lipo voltage alarms cost about $14 canadian so i dont think im going to get one. i used my multi meter after the run and the battery was really hot but the voltage was nly somewhere around 7.6v ish. I have no idea wha this means but I hope you guys do
    Dec 2014
    Adirondacks
    2,135
    A hot battery is not good. Was the motor and/or the ESC hot also?
    Sep 2020
    13
    they were warm enough like usual
