Results 1 to 11 of 11
    May 2020
    Maine
    693
    Different hex styles?
    I bought these tires and I guess i didn't know they arent for my truck. There's no hex. Its just a round hole.
    Should I just return the tires? I hate it when I do this.
    Can somebody recommend an aggressive tire that has a hex hub like mine? Thank you...
    Sep 2020
    43
    That's odd. Only reason for round would be to seat bearings directly into the rim for a front wheel setup maybe?
    Stock slash is 12mm hex. So anything with that would fit, but consider offset as well. You can also get hex adaptors to run larger wheels.
    Jun 2014
    San Gabriel, California
    8,391
    I think the older 2WDs (Rustler/Bandit/Slash(?)) did not have hexes in the front tires since they did not have power going to them. They just had bushings. I think the Bandit still usues the bushings.
    Have fun!
    RC Qualifier Rocketzx1's Avatar
    Oct 2018
    Tennessee
    526
    Squeegie is right. The older models of the rustler/bandit/stampede all had bearing only front wheels, because they didnít have power going to them and Traxxas felt it was better to not have extra hardware on the front end.
    I think the 2wd slash was the first 2wd model to use hex adapters in the front axles, could be wrong though.
    May 2020
    Maine
    693
    Thanks fellas. I appreciate the clarity. I hate buying stuff and having it not be what I want it to be lol. Its what i ordered but just the wrong thing for my truck is all.
    I emailed them and they set me in the right direction. Im getting these.
    Sep 2020
    43
    Those look awesome!
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,413
    Most of the DuraTrax 2wd models still run bearing front hubs. I recently acquired a DuraTrax Evader EXT 2.4 2wd and it has those same front hubs.
    May 2020
    Maine
    693
    @Scott P Thank you. The rims are a little big for my liking. Looks more like a street tire than a mud tire in my opinion. I like the look of a small rim with a lot of rubber for a mud truck.
    @zedorda Yes i noticed most of their tires have that bearing type hole. Once i get my refund for the ones i just sent back, im getting the 2.8 Duratrax Lockup MT's.
    Sep 2020
    43
    That Lockup MT wheel and tire combo looks awesome! Duratrax is nailing it with there rim styles.
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    37,998
    Quote Originally Posted by Rocketzx1 View Post
    Squeegie is right. The older models of the rustler/bandit/stampede all had bearing only front wheels, because they didn’t have power going to them and Traxxas felt it was better to not have extra hardware on the front end.
    The electric Stampede and Rustler have always had hexes up front. The Bandit forgoes a hex up front, instead having simple axle pin and slot for said pin in the wheel; the bearings (or bushings) were always in the hub.
    The Nitro Stampede and Nitro Rustler, however, used bearings in the wheels like that.
    May 2006
    Murfreesboro TN
    350
    Cooleocool beat me to it but yes, the Rustler, Slash, and Stampede electric versions all used standard 12mm hex backed wheels, Nitro versions of pretty much all 2wd styles used two bearings one inner and outer on a stationary stub axle in the steering blocks, in a pinch I have used the bearing style wheels simply by using a socket head cap machine screw the same diameter of the factory electric stub axle just slightly longer to attach the nylock nut
