    Apr 2020
    Czech Republic
    14
    Rod ends: Traxxas vs. RPM
    Hi, I have a slash 4x4 converted to MT. Currently I am trying to reduce the awful slop in steering. Already changed the bellcrank for aluminium one and that helped A LOT. I also found out that my rod ends have also noticeable slop on both sides. It’s probably due to the heavier tires and rolovers/hard landings. I want to change them but I need your help. My 2 options are TRX and RPM ones (I wanna keep them plastic) Which one would you recommend? I know RPM are made from softer material, but doesn’t that mean they will have bigger slop after the same period of time as “harder” TRX ones?
    Thanks for any input.
    Monster Sl4sh HCG w/ HW Max10 SCT|Castle 2650Kv
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    38,019
    If you want to stick with plastic, I'd just get the Traxxas rod ends. I like RPM parts, but I've had very few issues with the Traxxas rod ends that would make me want to switch.
    Dec 2003
    Dekalb, IL
    3,344
    The RPM ones stretch/wear just as bad/quick as the traxxas ones. I tried them on my stampede 4x4.
    There's a lot of slop in the steering on this platform.
    I have a thread where put bearings in the ackerman bar on my hot racing steering rack:
    https://forums.traxxas.com/showthrea...h-stampede-4x4
    And another where I got GPM c-hubs with bearings for the king pins:
    https://forums.traxxas.com/showthrea...=1#post6544847
    Now the only slop is in the servo itself, the upper turnbuckles, tierod ends and hinge pins.
    Apr 2020
    NL
    261
    Do metal rod ends help? Or do they make the rods themselves break
    Indianapolis
    14,572
    How well is it still holding up? I may have to do something similar for a winter project since I now live where it snows.
    Dec 2003
    Dekalb, IL
    3,344
    Quote Originally Posted by The Bean View Post
    Typically, they snap the rods going into them. I tried them a few times for shocks, didn't end well. Easier to replace a busted shock end when out bashing than a shock shaft. Would assume the issue would be similar on tierods. I'd make sure to have some spare ones on hand when out running if you want to try metal ones. Also, make sure to locktite them.
    I haven't run it a lot. My 6S trucks have been consuming my time. I have 12 bash sessions on the GPM c-hubs with bearings and 2 with the modified Hot Racing ackerman bar with bearings. So far, no issues... and I'm never easy on the thing.
    This was right before a landing that snapped a front GTR shock shaft:
    So, the c-hubs and ackerman bar are getting a workout.
    Apr 2020
    Czech Republic
    14
    Thanks for the tips guys!
