Hi everyone, for a out door dusty track what kind of tires are you guys running? and do you run same tread pattern in the front or should you run ribbed? Thanks.
Are we talking loose sorta dusty, or hardpacked sorta dusty? I always ran ribbed tires up front when not using "all terrain" tires.
Hi off road run a ribbed front tire on loose surfaces as will make model easier to drive.
TRX 6773 same as rustler 4x4 work well on rear of 2wd and give great grip
The track is hard packed with a layer of dust, thank you Richard.
