    Oct 2020
    X-Maxx Lost front wheel drive
    Took My X-Maxx out for the first time yesterday and within 10 min lost front wheel drive the main shaft turns if I turn the front wheels by hand guessing I broke whatever it links up to in the rear. any one else have a similar issue?
    Thanks.
    Mar 2016
    1,343
    Disassemble an have a look
    fabricator
    Apr 2015
    Tinley Park, IL
    330
    Get on you tube. Once you see how itís done itís not difficult to take it apart.
    Hopefully itís just a set screw that came loose or something simple.
    My 3 year old 8S has never had drivetrain issues.
    Had a spur gear shatter has been my only problem but Iím not a air or speed junkie like some around here.
    Donít despair. They are really good trucks.
    Feb 2020
    1,371
    Took out this wheel and check all the parts and threads, if necessary, use thread locker.
    Nov 2019
    100
    I'd start with pulling the front diff and seeing how the gears look. It's really easy to get to
    Apr 2020
    12
    I just had this happen to me, the way I figured out what was wrong was I disconnected the front end from the truck and spun the center drive shaft on it, both fronts spun so I knew the problem was in the back half. Then you can do the same with the rear to see if itís a differential problem or just the center drive shaft.
