Results 1 to 23 of 23
    Sep 2020
    19
    New E-Revo VXL, ran once, front now sags
    I only ran the model once. I had one rough, head-on collision, but there was no noticeable difference afterward. When cleaning it up later, I noticed the front end suspension sags significantly more than the rear. I notice, because I was impressed with its ride height and suspension when I first unboxed it (just above parallel in front and rear). Now the chassis is not parallel to the ground, either when dropping it from 6 inches or when letting the weight of the car settle the suspension. I notice I do have one bent tie-rod in front. But this would not cause such significant sag. Thoughts?
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,785
    Quote Originally Posted by Phaedrus View Post
    Welcome. Tapatalk for some pictures.
    The push rods if bent. Or a bent shock shaft could do it.
    Sep 2020
    19
    Thank you for the response. yes, one push rod is bent. But the other is not.
    Front, dropped from 6 inches high:
    Rear, same:
    RC Qualifier Rocketzx1's Avatar
    Oct 2018
    Tennessee
    567
    The bent push rod will do it. You can grab a set off eBay for cheap.
    RC Qualifier Calebs0615's Avatar
    May 2020
    Maine
    891
    If that's the tire that's sagging and the only problem you see is that rod is bent, I would say you just need new rod. Im sure that'll fix your issue. Theyre cheap too so it could've been worse in my opinion.
    Sent from my LGL722DL using Tapatalk
    Jul 2018
    beaverton oregon
    1,785
    Replace or at least order new ones and bend old one back into place as best as possible. Preload the springs some as well.
    I tend to push car down till chassis on ground then preload the springs till almost tight. Then back off as needed for terrain conditions.
    Dec 2018
    58
    it seems too low to have just the push rod bent
    it looks like you don't have shock absorbers
    the push rod is bent a little ..... take a soft hammer and it will be as before
    Inviato dal mio SM-A310F utilizzando Tapatalk
    Sep 2020
    19
    Quote Originally Posted by emi202071 View Post
    Thank you everyone for the replies. It does seem (to me) too low just to be due only to one slightly bent push rod. But I have replacements and will swap them out later today. Will post results.
    Sep 2020
    19
    No change whatsoever, with new push rods.
    Sep 2020
    19
    Quote Originally Posted by Rocketzx1 View Post
    Didn't work...
    Aug 2020
    I would guess shock preload needs adjusting. Can you take some pictures from different angles?
    Sent from my SM-G965W using Tapatalk
    Dec 2014
    Adirondacks
    2,467
    You can adjust the preload on the shocks to raise your truck back up.
    Sep 2020
    19
    Aaaaaaand one of the new pushrods sheared after 5 minutes of running. Never even got it up to speed, never even took a tumble. It just sheared. $25 for this? Thanks, Traxxas.
    Oct 2018
    Tennessee
    567
    Either the pic you took is slightly off center, or one side is hanging down lower than the other. I’d the bent push rod wasn’t the fix, pop off the shocks and check them out. I had a slightly crushed spring retainer and it caused the front to droop down. That’d be my next suggestion.
    Sep 2020
    19
    Thank you for the suggestion. I think the picture's a little deceptive because it was taken off center and taken so close to the vehicle, creating a slight fisheye effect.
    Dec 2014
    Adirondacks
    2,467
    With the pushrod unhooked does the a-arms and wheel move up and down freely?
    Sep 2020
    19
    Yes. And you requested pictures from "different angles". What would you like to see?
    Sep 2020
    19
    I am thinking I have done something to the chassis or front bulkhead. I did have one head-on impact, but I didn't notice any performance issues from it. Mateo from Traxxas support mentioned these two ideas. Will check and get back to everyone.
    Apr 2020
    72
    How tight are your pillow ball caps? Maybe you overtightened them during cleaning?
    RC Champion RICK DIZZLE's Avatar
    Sierra Vista, AZ
    1,417
    Can you take a pic from the top down like this? Curious to see your shocks and preload along with the position of your rockers. Wonder if its a bent rocker post?
    Sent from my SM-G955U using Tapatalk
    Jul 2018
    beaverton oregon
    1,785
    Quote Originally Posted by RICK DIZZLE View Post
    Rick Your cars are always to ****ed clean and pretty we need to see pics of em covered in mud
    RC Qualifier fuzion's Avatar
    Athens, Greece
    701
    yeah right. welcome to this world of -never like new- insanity, i have been there for years.
    the very smooth suspension play and accurate return to normal chassis height that the car has when its new, is really difficult to reproduce once played, forever. some say adjust preload, but that would just cover-up things that prevent the original smooth behavior.
    i believe that:
    - all suspension connections collect dust/dirt
    - all bearings collect dust/dirt
    - suspension parts bend slightly
    - shock oil and internal parts are degrading
    - springs might degrade (unsure about that)
    the above imo prevent the car suspension operate smoothly, therefore we do stuff like adjust preload or stiffen up springs to bring the chassis back where it was after a push down.
    a nice test is if the suspension arms move freely without shocks connected, but still a slight cog there (impossible to detect with the test) might prevent the chassis go up in normal operation.
    after trying everything, i stiffened it up and stopped worrying at some point. i hated it.
    Sep 2020
    Kent
    24
    Hiya
    The springs will sag a touch after first run you just need to adjust the preload collars back down on the shock body to raise the ride height
