Results 1 to 2 of 2
    Apr 2015
    Tinley Park, IL
    330
    Mip X-Duty steel wheel nut set screw
    I love my X-Dutyís, but always take your time and heat them if the set screws donít back out with reasonable pressure.
    If you break you screw driver tip off in the set screw this is what you need to do to remove the 12mm nut.
    The out drive is what happens when you strip the set screw inside the joint.
    Luckily I had a rebuild kit on hand and I was converting it from back to front anyway so no serious damage done.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,450
    I have had to replace only 2 so far of these. I used a reverse cut drill bit and before I drilled through they came loose from the heat. It ruins the drill bit but they are cheap enough to replace.
