Results 1 to 8 of 8
Thread: Toe Links
    RC Racer yogertdog's Avatar
    Nov 2015
    Idaho
    167
    Question Toe Links
    So i bent a toe link on my 4x4 rustler and I'm wondering what kind of toe links are the most durable?
    The stock ones are steel and that's what I bent but traxxas also has aluminum tubes and composites, what material is the best for toe links? Also are there any aftermarket brands that make a good cost-effective link?
    Feb 2020
    Morristown, NJ USA
    217
    The most durable I’ve come across and use on all 4 of my 4 x 4 rustlers are Lunsford Turnbuckles.
    https://www.amazon.com/Lunsford-Tita.../dp/B00LMJOIEW
    As of today’s date, I have not broken one. A bit pricey but so worth it.
    RC Qualifier Calebs0615's Avatar
    May 2020
    Maine
    904
    If you bent an aluminum one, using a plastic one will probably also break. But maybe you can try rpm?
    Sent from my LGL722DL using Tapatalk
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,487
    Less expensive option but still stronger than aluminum or plastic. Try threaded bar stock and a few nuts to threadlock in the middle so you can adjust them simply. You can buy it from most hardware shops and they will cut to size but don't get them cut to exact size go over and cut them down at home. They rarely have super accurate cutting methods. Might not be titanium but steel works great for bashing and you can get several for the same price of one aluminum.
    68
    I run the traxxas 6742, their plastic and flex a bit on big jumps. But I havent broke one yet and I run proline badlands which are some pretty big tires.
    Rustler 4x4 powered by MambaX
    Jul 2020
    137
    FYI, Traxxas claims their aluminum linka are "stronger than titanium", well, cool and all, till u snap one clean off after a MINOR cartwheel through the neighbors yard. Hella-disappointed for such pricey POS's they really are. Also, becoming less and lesa of a an RPM "arms" fan
    , Sure theyre flexible, but they also seem to HOLD any deformation, like staying rather "twisted" after a hard hit, ie; the r.f. arm-front, points up to the sky at a moderately noticeable angle... And cause a whole **** of an alignment mess
    Sent from my Pixel 3a using Tapatalk
    Jul 2019
    Washington
    91
    Quote Originally Posted by Trx4newb View Post
    Traxxas' A-Arms >
    Oct 2020
    Maine
    17
    Quote Originally Posted by afreek1000 View Post
    Where do you get the rest of the pieces to make these work? I'm not sure what to call them, the ball and socket type connections that screw onto the ends of these?
