    Oct 2020
    tmaxx 3.3 foc stuck in reverse
    i have a tmaxx 3.3 that i acquired used for very cheap and ive been all through the truck, it seems as though it has a forward only trans, and yet its only engaging the drive-line in reverse. ive even swapped the front dif to the rear to see if that would make a difference with no change does anyone have any ideas? what way should the trans be spinning? right now i think its engaging clockwise . ive had the tranny apart and the oneway bearing looks good and same withe the pin that is known to shear off, im at a total lost.
    Oct 2020
    i fliped the diffs over so im gonna test it tommorw and see if that was the issue hoping for the best
    Mar 2016
    1,340
    Should be good to go now
    Been there done that
    fabricator
    14,226
    Flip the diffs. If I recall the screws should be on the right as you look at them.
