Results 1 to 15 of 15
    969
    Strip this screw and you are never getting your Front Assembly off, correct?
    I came this close today and cant even begin to imagine how you would remove it if you stripped it
    https://ibb.co/TR2hHN2
    Mar 2016
    1,349
    Could drill the head off
    fabricator
    Apr 2015
    Tinley Park, IL
    332
    A set of small diameter screw extractors are always in my tool box.
    You can get them at most hardware stores.
    May 2019
    212
    Cut the cheap stuff off first.
    Feb 2020
    1,399
    Quote Originally Posted by Dmarzke View Post
    Totally agree with this.
    969
    Quote Originally Posted by CrazyXMAXX View Post
    what does that mean?
    Quote Originally Posted by Clubin View Post
    what do you mean cheap stuff?
    14,232
    Quote Originally Posted by varunaX View Post
    Drill off the head of the screw which may allow removal of the part it is attached to.
    The "stuff" that does not cost much to replace. Better to sacrifice a screw versus a bulkhead, for example.
    969
    How can you drill off a head that is recessed 2 inches deep?
    Not sure howd you'd cut off the chassis to remove thst screw if thats what you mean
    I guess I'm just complaining about the poor design of such an important screw being so recessed. There are no screws like that on any of my other traxxas cars
    14,232
    Then use quality tools, the proper size hex and don't strip the screw. I don't own an X-Maxx and I'll assume it is screwed into plastic. The only time(s) I've stripped screws threaded into plastic is when there is limited access which resorts to using the driver at an angle or one with a ball-end.
    Feb 2020
    1,399
    In the composite materials like the X-Maxx chassis, never tighten the screws with excessive torque.
    VarunaX, you can use a set like these in the link to took off this screw, there are a variety of measures.
    https://www.google.es/search?q=screw...ncrkhwCbwv-6KM
    Feb 2020
    70
    punch the screw out from the bottom.. if its stripped anyway.. its just plastic
    Dec 2003
    Dekalb, IL
    3,374
    Quote Originally Posted by whoflungpoo View Post
    Guessing the issue is the head strips.
    I find that happens a lot with 2mm button/flat head screws, but not nearly as much with 2.5mm or larger screws. Whenever possible, I ditch 2mm buttons heads with 2.5mm cap heads just for that reason.
    Oct 2020
    Calgary, Alberta
    5
    Before drilling the head of a screw that is in plastic - try using a left handed drill bit. I have found these will bite into the screw head and backout the screw. Worst case is you use it to drill the head off, but I would expect it would back out.
    Feb 2020
    1,399
    Quote Originally Posted by donnie533 View Post
    Very good idea too.
    Oct 2020
    Dallas TX
    333
    Yeah, screw extractors are made specifically for this reason. You can find them on Amazon for decently cheap. The one below would work.
    https://www.amazon.com/Extractor-Str.../dp/B07GZ17QD9
    The present is theirs; the future, is mine.
