Results 1 to 9 of 9
    Aug 2020
    104
    trx6 intermedate axle wont transfer power to rear axle
    my trx6 intermediate axle wont transfer power to rear axle it just grinds like the pinions are not mashing right but when I open it up everything looks normal no chunks are missing. not sure what I need to replace
    15,607
    Do you hear grinding gears?
    Sent from my moto e5 cruise using Tapatalk
    Ya can't polish fertilizer...
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    987
    Check to see if all the bearings are seated all the way down, sometimes the bearings aren't all the way in making an imperfect mesh.
    Aug 2020
    104
    yea I get a grinding noise all the bearings seem to be seated well I think im going to try swapping the gears from the front axle into the mid and see if that helps
    15,607
    You have opened both axles, all gears look good? Hmmm
    Dec 2014
    Adirondacks
    2,426
    Have you checked the rear axle gears or just the mid axle gears?
    Aug 2020
    104
    both the rear works fine the middle acts like its skipping teeth with any resistance
    RC Qualifier TITANIUM94010's Avatar
    Sep 2019
    San Francisco CA
    529
    Have you possibly disconnected the axle by not inserting the pin/grub screw? Check on the axles if the grub screw is still there. Try spinning all the gears by hand or with a tiny bit of throttle with the diff open, and see what's not spinning.
    Jumping: maneuver and pray it won't break.
    Aug 2020
    104
    ended up ordering the 8279 ring and pinion gear just sucks I have to order two because they dont sell just the pinion and I need two
