Front differential question
What’s the difference between going with the 42 tooth ring gear/13 tooth pinion versus the 35 tooth ring gear and 11 tooth pinion?
The 42 tooth shouldn’t be used with the 11 tooth, correct?
6s Xmaxx gears are not worthy
7790
7791
7792
8s Xmaxx front and rear
Rarely ever fail
7790, 7791 and 7792 are 6S gears or 8S gears?
Just realized those are the 8S ones, thanks!
The 8S ones are are more harder than the 6S ones, better quality material.
- You may not post replies
- You may not edit your posts
Forum Rules
