Results 1 to 19 of 19
    Aug 2020
    19
    Slash body preservation?
    Any tips for not destroying bodies? I don't mind messing one up from flips and crashes, but I feel like mine get chewed up driving over bumpy ground fast and tires ballooning? Any tips to prevent this or is it just a design flaw that makes options like the Rustler that move the tires outside the body a little more attractive?
    May 2020
    Maine
    808
    Quote Originally Posted by MAKDaddy View Post
    I use proline adjustable body mounts on my slash 2wd. I had to when i got the bigger tires. I think that's what you're looking for. This is the link to them.
    https://www.amainhobbies.com/proline...087-00/p237048
    Aug 2020
    19
    Thanks, I guess the Badlands are a bit bigger than the stock tires. I bet these will work.
    RC Champion Panther6834's Avatar
    Jan 2019
    SF Bay Area
    1,132
    You can also spray the inside of the body work truck bed liner (just not too thick). It will add a minor amount of weight, bit will provide far greater disability. Lots of others have done this, and tend to be extremely pleased with the results. If you look at my custom-painted Baja Rey body, you'll notice what I'm talking about (the 'black' final coating).
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
    Jan 2020
    not in an ocean
    254
    I have heard of people using drywall tape and shoe goo to add durability to a body.
    Jan 2019
    SF Bay Area
    1,132
    Quote Originally Posted by TRAXXASAXXART View Post
    I've never heard of anyone using drywall tape. However, as for ShoeGoo, yes.
    May 2013
    367
    Quote Originally Posted by Panther6834 View Post
    Many of us use drywall tape and shoe goo. I use the self adhesive drywall tape in the key areas that always crack.
    Jun 2014
    San Gabriel, California
    8,476
    Shhe Goo and drywall tape if the go-to solution for most. I also use aluminum foil tape and line where rubbing would happen (body posts, nerf bars and wheel wells).
    Good luck and have fun!
    Jan 2019
    SF Bay Area
    1,132
    Aluminum foil tape I wasn't aware of. Thanks for the "idea/duggestion", Squeegie (btw, luvin' the Vitavon wheels for the Baja Rey...you & Arthur did another outstanding job).
    Mar 2017
    474
    Yep, alum tape for rub areas.
    Imo, spot reinforcements are better than all over coatings.
    There is a Lexan reinforcement panel that Scrorched Parts makes for the Slash body...
    Jun 2014
    8,476
    ??? Not me. I’ve never purchased Vitavon parts for me rigs...
    Jun 2020
    Texas
    219
    I’ll third the aluminum tape underneath the body. It doesn’t stop flips and such from crushing, but it keeps the tires from rubbing for sure. I have almost my whole inner body covered in it.
    Apr 2020
    NL
    265
    The body still cracks, but the glue keeps it together. My body is almost in half, but stats together because of the glue.
    Also, the aluminum tape helps a lot against tire rub.
    Jan 2019
    SF Bay Area
    1,132
    Will be picking up some of that aluminum tape soon. Suggestions on where to buy? Home Depot? Lowe's? Auto parts store?
    Oct 2020
    In the hot desert
    10
    Normally you can get that tape at a hardware store. It's used mostly for HVAC ducting.
    Jun 2014
    8,476
    HVAC ducting tape (foil tape) can be found at Home Depot and other hardware stores.
    Have fun!
    Jan 2019
    SF Bay Area
    1,132
    Have fun!
    Will do...and always try to (when I'm not allowing an FE propeller to almost chop off thumb). How to have an update on my Baja Rey build thread within the next 1-2 weeks.
    Bigger tires will, obviously, increase the probability of rubbing the body. In addition to protecting the inside of the body by whatever means you choose (as a few suggestions have been given), considering the larger tire diameter, I would probably recommend going with calebs' recommendation of the Pro-Line adjustable body mounts, and mounting the body one...maybe two..."steps" higher. Doing so might expose some of the electronics/battery on the sides of the chassis, but this can be "corrected" through other means.
    Jun 2014
    8,476
    I've never heard of anyone using drywall tape...
    Aluminum foil tape I wasn't aware of...
    Here you go:
    Some people use the Shoe Goo and Drywall Tape over the entire inside of the body, and some just where the weak points on the body are. Do as you see fit...
    Note: Use the Sho Goo outside unless you like the smell of it....
    Have fun!
    Jan 2019
    SF Bay Area
    1,132
    Here you go:
    Have fun!
    FANTASTIC...thanks for that YouTube link. Considering how much I paid for the custom paint job on the BR body, I'm thinking reinforcing in certain areas, and adding a lil summoning tape, could prove to be a very smart idea.
